MR console on 5spd shifter: making the shift boot look like it fits
Old May 29, 2012 | 04:00 PM
deeman101's Avatar
I noticed many people like me are annoyed by the fitment of the MR console's boot on the 5spd shifter. But I don't like the look of the GSR/RS console. The biggest problem is the boot slides up and down the shifter when you go from 1st to 2nd, etc. so its clear it doesn't fit. So heres a way to make the shift boot look decent.
Materials: double sided tape
1. Undo the button on the boot.
2. put a small piece of double sided tape on the front of the silver bulb part. Put it low on the metal so you can't see it when the boot is done up.
3. put a small piece of double sided tape on the back of the silver bulb part. Again, put it low.
4. do up the button on the boot.
5. firmly press the front and back of the boot on to the double sided tape.
Results:
Neutral
1st
2nd
3rd
4th
5th
reverse
Its not perfect but at least it takes a keen eye to notice somethings not right. And don't mind my crooked shift knob.
Old May 29, 2012 | 05:20 PM
foxbear2277's Avatar
Looks ok, better than having it slide up and down and look like garbage. Looks best as a simple temperary fix until a new shift boot is made
Old May 29, 2012 | 06:13 PM
deeman101's Avatar
I'm actually probably going to put a short shifter in it. And generally the metal bulb part on most short shifters is large enough to allow for the stock shift boot to mount securely. Personally I like the way the MR shift boot mounts securely on the shifter itself vs kinda floating on top of that bulb (stock 5spd boot). You probably already guessed but I like to have my car look completely OEM.....but not perform like it.
Old May 29, 2012 | 06:42 PM
Good to know about the short shifter and the 6 speed boot, I will be performing 5 speed swap and will now definently see how the boot fits compared to the oem shifter
Thata boy, stock appearing... but far from stock
STLEVOIX
Mar 10, 2015 08:45 AM
zcchenCT9A
For Sale - Cars For Sale
13
Dec 14, 2011 05:34 PM
evidence01
Sep 7, 2011 10:38 PM
visieon
For Sale - Part Outs
30
Aug 1, 2011 07:38 AM
Ian0611
Jun 3, 2011 11:09 PM
