Mishimoto fan install, please help
Old Oct 17, 2012 | 01:04 PM
fastyouth1313's Avatar
I would like to see pix of where people mounted the fan module. That's the problem I'm having.
Old Oct 17, 2012 | 01:52 PM
GBAILEY472's Avatar
Originally Posted by fastyouth1313
i would like to see pix of where people mounted the fan module. That's the problem i'm having.
x2
Old Oct 17, 2012 | 02:03 PM
meckert's Avatar
Please post pix, or pm me for my email. PLEASE!!!! I've had the fan/shroud for over a month and trying to figure out what to so with it
So shoot me an email address and i will send it to you. I took a pic, I will tell you now its from under the car and not a lot ot look at. You will see the intake pipe and If I am not mistaken I used the mounting hole for the 3 port boost controller--or 2 port if you s are stock, on the frame--drivers side. just mounted the module there by 1 ear, with wires facing downwards, so any water doesnt puddle up and cause a prob.
Old Oct 17, 2012 | 03:33 PM
EvoStevo777's Avatar
i just ordered a mishimoto radiator im on stock turbo do i need to buy a new fan or could i use the oem fan
Old Oct 17, 2012 | 04:29 PM
snafufx's Avatar
hope this helps. basically took 2 zipties, ran it through the radiator and mounted. just use the very last fin on the end since zip-tying causes the fins to bend.
Old Oct 17, 2012 | 06:18 PM
Thanx guys!!!
Old Oct 24, 2012 | 09:28 AM
GBAILEY472's Avatar
I decided to use self tapping screws and mount it on the frame.
Old Nov 15, 2012 | 06:15 AM
khasal's Avatar
Excellent thread. Im assuming the module is necessary as no one here mentions deleting it. Is anybody running without this module and if so, how effective is it? Does it run constantly? I WOULD LIKE to wire my fan to run Constantly.
Any ideas?
Old Nov 15, 2012 | 09:24 AM
teamrevjohn's Avatar
This is awesome! Thanks!
Old Jan 13, 2013 | 10:09 AM
Bobster22388's Avatar
Unfortunately doing it like this the module and its sensor (the whole aluminum face with all the little dimples) will not read the temperature of the radiator so it may come on after a long delay. Having it right behind the radiator makes it come on as needed sensing the actual temperature.
Old Jan 13, 2013 | 10:10 AM
Any ideas?
The module is only necessary if you want to the fan to come on and off as needed. If you delete the module and just connect the positive and negative wires to your fan, it would run all of the time that your car is on.
Old Jan 13, 2013 | 08:06 PM
02-Lancer-Es's Avatar
It does not matter were it is mounted there is no sensor on the box it is just a high and low relay .
Old Jan 26, 2013 | 02:25 PM
PAdutch's Avatar
Did you guys just splice the wires in? Did anyone disassemble the plug itself and put the new wires in it? Like a dummy i pulled a wire out of the plug.
evo082006
Apr 17, 2015 02:05 PM
Juan Martinez
Aug 5, 2014 03:21 PM
JBAutosports
EvoX 'For Sale' External Engine / Power
97
Nov 18, 2012 05:04 PM
JBAutosports
101
Nov 18, 2012 05:03 PM
acssa
May 31, 2011 07:06 AM
