help walbro 450 vary low pressure
ok guy i been fighting with this for a week . new walbro 450 new fic 2150cc and new fuel lab regulator .. when i turn the key on i get prime when i try and start the car i get power to the pump @8.8 volts.. some times i can get the car to start idle for 1 sec then seems like it runs outta fuel .. i dont know what els to do at this point . i do not have it hard wired some people have told me to and some not to .. any help or advice would be great .. thanks guy .
8.8 volts seems pretty low, even for cranking voltage. I would assume you should get somewhere in the 10.0-10.2 volt range. Someone correct me if I'm wrong with those specs. What's the voltage KOEO??
Ok guys I ended up taking my car to boostin performance in Chicago and come to find out I had a bad fuel pump right off the bat .. I'm sending it back to extrem-psi and there sending it in to walbro . Hope I get a refound seeing how this just cost triple . At least its fix and I'm hoping to put down some good dyno number this coming week . Thanks everyone for your advice
Brass
Nov 15, 2016 05:02 AM
clash0901
Jun 3, 2016 05:27 AM
WTB[MidWest]: ISO speed density supplies
murderedout
Mar 4, 2016 11:05 AM
YFZracer32
Oct 19, 2015 12:03 PM
