Help replacing alternator!!!
Old Aug 13, 2014 | 07:57 PM
bckeye's Avatar
My alternator went bad so im replacing it, I have read all the threads I could find with many different ways of doing it. I have gotten the alternator off the engine just cant seen to get it out of the engine bay. It seems like removing the throttle body and battery and pulling it out the driver side may be the easiest route but cant find a walkthrough for removing the throttle body.
Is it easier to remove the passenger axle shaft and pull out the bottom? I have replaced the clutch and the passenger side shaft is not the easiest to remove and replace.
Thanks for any info!!!
Old Aug 14, 2014 | 07:08 AM
jspecteggy's Avatar
A little further down the page I found this.
https://www.evolutionm.net/forums/ev...nator-top.html
Old Aug 14, 2014 | 07:35 AM
Boostlife4g63's Avatar
^^^ good one jspecteggy^^^ taking it out through the top passenger side is perferable as per most evo owners!
Old Aug 14, 2014 | 09:06 PM
steveliu30033's Avatar
good how to guide.
Old Aug 15, 2014 | 04:34 PM
bckeye's Avatar
It just won't come out the top, I can't get the alternator bracket off because of the idler pulley so there's no room to het it out. I'm trying removing the axle and pulling it out the bottom.
Old Aug 15, 2014 | 06:42 PM
bckeye's Avatar
The bottom doesn't work either, the green plastic boot on the transaxle doesn't come off with the axle so it doesn't give enough room. I'm stumped an most if the front end is apart.
Old Aug 16, 2014 | 03:30 PM
bckeye's Avatar
FINALLY!!!!!! I only had to disconnect the driver engine mount and the main cross member underneath to drop the motor a few inches to make room to pull it out the top. That was almost ashard and complex as replacing the clutch!!!
Old Aug 23, 2014 | 03:59 PM
Lueee10's Avatar
almost had to look into this recently, gave me a scare, didn't want to have to replace. its all good under the hood though
Old Aug 29, 2014 | 11:43 PM
ZanarkO's Avatar
damn I had to pull my axle out when I did this on my 05 good show!
Old Aug 30, 2014 | 05:26 PM
bckeye's Avatar
Thanks!!!
MitsuJoe
468
Feb 20, 2016 11:17 AM
JonGonzo
Jun 27, 2015 12:49 PM
MarkS
Apr 17, 2014 06:39 AM
Douglas_Hammon
12
Aug 31, 2012 09:06 AM
mfr122887
Mar 18, 2008 01:32 PM
