How to bleed ACD pump
Old Dec 29, 2015 | 07:04 PM
MR.EVO00's Avatar
ACD pump has all three lights on so i took it apart cleaned it put it back in now I can't bleed the system because of all three lights being on still. how do I bleed the system any help would be great thank you.
Old Dec 30, 2015 | 06:38 AM
MR.EVO00's Avatar
Bump
Old Dec 30, 2015 | 11:17 AM
escodotcarter's Avatar
There is a lot of info regarding this on the forums if you'd like to research more on this.
You can do three things:
1. if you have a laptop/evoscan/tactrix cable then you can bleed via the evoscan software making it a 1 man job basically.
2. you can turn the key to ON position and floor the gas pedal. This activates the acd pump for a few seconds. This would make it a 2 man job (1 in the driver seat and the other under the car opening/closing the bleeder screw)
with option 2 you have to keep repeating this process. also be sure to top off the acd reservoir so you don't introduce new air into the system.
3. run direct power from the battery to the pump to get it to activate. 2 wires and gator clips or some sort of slip on connectors works well.
Old Dec 31, 2015 | 06:51 AM
Syringe's Avatar
I have had to drop my transfer case/tranny a couple times on my Evo IX MR and I did this method, never any issues, worked like a charm.
Old Dec 31, 2015 | 03:56 PM
MR.EVO00's Avatar
Thanks for the input I'll keep you posted
Old Jan 13, 2016 | 05:04 PM
MR.EVO00's Avatar
Hey
Old Jan 13, 2016 | 05:08 PM
MR.EVO00's Avatar
So after taking apart the pump I put it back together now that all the corrosion is cleaned off. I bled the system by pressurizing the reservoir and still all three lights are on what gives
Old Jan 20, 2016 | 08:17 PM
MR.EVO00's Avatar
Turns out was the relay for the pump
Old Jan 21, 2016 | 07:27 AM
wow, that should have been the first thing you checked. Hey on the bright side at least you now know the inner workings of an ACD pump.
Glad to hear everything is fine though
Old Jun 6, 2019 | 09:29 AM
DAVID Mangone's Avatar
Acd Ralliart only location of acd bleeder screw?
06MREvo
For Sale - Part Outs
34
Nov 18, 2014 01:05 PM
NOMIEZVR4
Oct 18, 2013 01:28 PM
1badgsex
14
Jul 14, 2012 08:27 PM
DubsE46
10
Dec 30, 2011 04:48 PM
Kidloco51
Sep 20, 2011 12:36 PM
