Valve Cover Leaking
Valve Cover Leaking
So I installed a set of cams on my Evo 9. I made sure to put gray rtv on the number 1 intake and exhaust cam bearing caps. I even put gray rtv on the valve cover gasket. It's hard to tell but it looks as though it is leaking from the valve cover gasket right around where the cam gears are located. Should I have used a different rtv sealant? Has anyone encountered this issue?
ethan169
13
Jan 17, 2012 02:28 PM
Turbo Kyle
Aug 18, 2008 08:07 AM
RevMoto
Sep 30, 2006 07:56 AM
