Exedy Twin Disc Install - Video
Old Apr 30, 2019 | 06:42 AM
DontStopMe's Avatar
Still working on my evo and documenting everything. Comment with your trips or tricks as well!
Old Apr 30, 2019 | 07:04 AM
Well Done Paul @DontStopMe
Old Apr 30, 2019 | 02:56 PM
2006EvoIXer's Avatar
Did you modify the basket like what Jacks Transmission recommended to help with clutch drag?
https://www.jackstransmissions.com/b...clutch-warning
Old Apr 30, 2019 | 04:26 PM
DontStopMe's Avatar
I did not. Has anyone else had this issue?
Also wish that was more detailed, seems a bit vague.
Old May 7, 2019 | 03:18 PM
Pal215's Avatar
You are right about that, it is vague. Thanks for going out of your way and using your own time to post such helpful videos. The phenomena they are talking about is that when you release the clutch slowly in your car and you feel one clutch disk grab before the second. It can also be when you press the clutch pedal and the clutch doesn't completely disengage because the floater plate is lodged up against the flywheel towers due to friction, keeping a clutch disk engaged with the flywheel. It's a bit difficult to describe unless you feel it haha. There are also complaints about noise and that apparently this is a way to lower the noise too. Here are the parts that you can polish.
I choose to sand these 6 clutch towers on either side with 800 grit sand paper up to 1500 IIRC. You can also polish the sides of the floater plate (or plates if you have the triple) that contact either side of these towers to reduce noise and smooth engagement. They just need to be able to slide easy on each other. It is definitely NOT worth dropping the trans to do it though.
Old May 8, 2019 | 08:01 AM
heel2toe's Avatar
I wonder if Exedy has addressed this in recent years? Reason I mention that is bc when installing my twin about a year ago I planned on polishing the towers per what I had read in the past however mine appeared to already be polished and fairly smooth. Perhaps it would have been advantageous for me to still polish it however I opted to install as is. No issues shifting as of yet but still way too early to tell.
Old May 8, 2019 | 10:21 AM
LetsGetThisDone's Avatar
I've installed a few in the past 2 years, and they did not need polishing, they had a smooth machined finish.
Old May 8, 2019 | 10:23 AM
Pal215's Avatar
One would think that it wouldn't be too much trouble if they did address it, but exedy themselves probably don't think that the polishing does anything. In fact, it's counter intuitive because the tower surfaces are already smoothed out enough from factory so that the floater plates and clutch disks slide freely on them .
I did polish mine when I owned an exedy, but I felt strange doing it. I thought that if you polish two surfaces with the same grit, you would actually cause the opposite effect and make them have more friction against each other since the microscratches on each surface, (peaks and troughs,) are now similar to each other, causing more grip. I'm probably wrong about that though.
Old May 8, 2019 | 10:33 AM
DontStopMe's Avatar
Thanks for the info.
I talked to a shop that does a lot of evo work, and they said they don't polish them when its brand new set-up. So i'm not too worried. But i'll report back if i have issues.
Old May 8, 2019 | 10:54 AM
Pal215's Avatar
You got it I agree, it's definitely not critical at all, especially with new installs.
Old May 11, 2019 | 10:35 PM
deylag's Avatar
How many launches before you guys think this clutch needs to be replaced?
Old May 13, 2019 | 11:04 AM
Mine had 20k hard miles on it- probably 20-30 launches, road course (not always perfectly matched down shifts that **** the clutch off), and general street shenanigans, and the disks were at about 40%.
Old Oct 7, 2019 | 06:55 PM
DontStopMe's Avatar
