Easy way to fill tranny fluid
Old Nov 2, 2003 | 07:56 AM
simevo's Avatar
This is after you have drained, cleaned and installed the drain bolt.
Get a cheap pump for $4.00 at local auto store then pump away.
Old Nov 2, 2003 | 08:03 AM
simevo's Avatar
If you don't have a level lift, remember to just add 2.75 to 3qt max since not all old fluid will come out or you can add till the fluid drips out of the fill hole if you have a level lift.
The transfer case is similar to tranny, but you will only be able to add about 1/2 qt before it drips out.
If you can change your own oil, you can change all the tranny fluid including the rear diff. It's that easy.
Old Nov 2, 2003 | 08:08 AM
simevo's Avatar
And one more thing, you should get a second pump for the transfer case as it does not use the same fluid as the tranny. I would replace the transfer fluid more often than the tranny as it only holds about 1/2 qt and it gets pretty thick and dirty quickly.
Old Apr 12, 2004 | 08:47 PM
LancerEvoMR's Avatar
Discuss thread here
ryan010
27
Jun 23, 2016 10:31 PM
beetle_orange
May 6, 2016 07:42 PM
Gqracer
Apr 5, 2013 08:50 AM
chaotichoax
Feb 7, 2010 10:20 PM
navedog
May 25, 2006 11:36 PM
