How to: tranny/xcase/rear diff fluid changes
Old Feb 7, 2010 | 10:15 PM
chaotichoax's Avatar
Text and photos copied from socalevo.net
5/6 Speed steps
**6 speed is the same except the drain and fill plugs are both 10mm.**
1. Jack up the front of the car and put a jack stand under it.
2. Get a 17mm and 24mm socket and a catch pail handy under the car.
3. Undo the fill plug first (17mm) in order to avoid glugging (don't forget the washer!!!).
4. Undo the drain plug (24mm) second and drain all the fluid out. make sure to position the waste pail accordingly.
5. Screw the drain plug in (don't forget the washer!!!) and get a funnel with a long flexible spout (4 bucks from pep boys) and stick in the side of the fill hole.
if you use just the funnel with flex you'll likely have to remove your intake in order to fill from above. if you get some 3/8" rubber hose (about 18" should do) then you can seal off the fill hole (no leaking while filling) AND you don't have to remove the intake!
6. Pour new fluid in until it starts to come out of the drain hole (It is sideways) or around 3 quarts. YOU SHOULD ALWAYS FILL WITH YOUR CAR AT A PERFECTLY FLAT OR A SLIGHT POSITIVE INCLINE (front two wheels off the ground) this overfills the tranny as apposed to underfilling it and keeps things MUCH happier!!! this way it'll take 3 bottles of fluid and there's not guessing if you had too much spill out.
7. Put back fill plug. plugs should only be hand tight, torque specs are good, but don't hamfist them on or you'll be sorry!
5 speed pics
**drain and fill
6 speed pics
**drain
**fill
Transfer case steps
1. Open the fill plug first and clean the plug, be sure to remove both the plug as well as the metal washer. When I removed my transfer case fill plug, fluid ran from the fill hole so be prepared.
2. Put the oil catch pan underneath the drain plug and slowly undo the drain plug making sure that you also remove the metal washer. As the fluid drains, you may have to move the catch pan to prevent oil from leaking to the ground. drains real fast, only .6 quarts.
3. Clean the drain plug (you will find lots of tiny metal bits attached to the magnetic portion of the transfer case drain plug).
4. Once the stream of fluid has ceased, put the drain plug back. Be sure to remember to put the metal washer back on as well. If you have a torque wrench all the plugs should be tightened to 23 ft.lb.
5. Now, take the gear oil pump and run the hose into the fill hole. it's nice to have a hose long enough so you can sit the bottle on the ground and pump. but that just means more fluid that you're gonna have to pump back into the bottle when you're finished.
ALWAYS FILL YOUR TRANSFER CASE WITH THE CAR AT A PERFECTLY FLAT OR SLIGHT ANGLE SO YOU'RE OVER FILLING IT AND NOT UNDER FILLING IT!!! ALSO NOTE!!!
6. Pump the correct fluid into the diff. just keep pumping until fluid runs from the fill hole. it should take about .6 quarts.
7. Replace the fill plug. Be sure to remember the metal washer.
transfer case pics
**drain
**fill
Rear diff steps
1. Open the fill plug first and clean the plug, be sure to remove both the plug as well as the metal washer. When I removed my rear diff fill plug, fluid ran from the fill hole so be prepared.
ALWAYS FILL YOUR REAR DIFF WITH THE CAR AT A PERFECTLY FLAT OR NEGATIVE ANGLE SO YOU'RE OVER FILLING IT AND NOT UNDER FILLING IT!!! ALSO NOTE!!! clutch type differentials require a certain amount of friction to operate without chatter, you must use friction modifier for fluids that don't already have it mixed in. that stuff stinks like fish too, so just get the stuff that already has it mixed in.
rear diff pics
**drain and fill
Old Feb 7, 2010 | 10:20 PM
Discuss thread HERE!
SleepySamurai13
Apr 28, 2017 05:04 AM
josh_evo9
26
Dec 29, 2016 03:28 AM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
runny_yolk
97
Jun 12, 2012 10:14 AM
Djstorm100
Jun 11, 2009 03:38 PM
