Installing UR Test pipe without hacking o2 sensor wires.
Old Dec 30, 2003 | 05:59 AM
93civEJ1's Avatar
Well i have figured out with the help of "TurboDan" and a friend, how to install UR's Test pipe without cutting and extending the wires on the o2 sensor.
Here is a little step by step without pics (pretty self explanatory). Feel free to add input on ways you have either made it easier or problems you have ran into.
1. Go ahead and get the test pipe and cat switched out and screw in the o2 sensor into the bung, and get all of that ready.
Now for the fun!!
2. Open up the arm rest. There are 2 phillips head screws.....Take them out so you can lift up the console to get to one of the bolts on the seat for the next step.
3. Unbolt and take out the passenger seat and place aside. If i remember correctly, the seat nuts and bolts are 14mm.(Correct me if i am wrong and i will correct it.) There are 2 nuts on the front of the seat, and 2 bolts on the rear.
4. Take off the paneling under the dash on the passenger side on the front right hand side, there should be 2 little clips holding it in place, and they come out pretty easy.
5. Now take off the scuff plate paneling on the passenger side. Just pull it up kinda hard, and it pops outta place.
6. You may or may not have to unpop some of the paneling where the seatbelt on the passenger side is. I did do it.
**The reason for pulling up the plastic panels is for the next step.**
7. Lift the carpet on the passenger side, and you will find the body hole and harness that the o2 sensor uses.
8. Pop out the grommet that the o2 wires are going through and unplug the o2 harness. **You may want to buy a body plug to plug this hole back up...we wont be using this hole now...I did get a plug for this hole**
9. Look about 8" in front of the body hole you just popped the grommet out of and you will see another hole plugged up with a body plug. Go ahead and pop this one out as well.**This hole is slightly bigger than the previous**
10. Move the wire harness thats inside of the car to go through the new hole thats about 8" in front of the old hole.
11. Get under the car, and now plug the o2 clip into the o2 harness that is hanging out of the newest hole.
**Now these next parts are up to you, ----We will need to figure out a way to fill in the gap of the hole that the new wire is running through, we cant use the grommet attached to the wires as the hole is alittle too big for it to clip onto. At first i was just going to stick the rubber grommet attached the wires up to the hole, and use some RTV silicone or gasket maker to hole it up covering the hole....This will work , but i didnt have 24hrs to let it cure while holding it up, so of course it just fell back down. ----So next i went to Autozone and bought some JB Weld Kwik, so i could try the same thing, but it would dry fast...Im sure this would work as well, but me and my friend came up with a better solution and this is what i did.--1. We took the body plug that came out of the new hole, and cut a slit in it from the outside edge of the plug just to the center of it. 2. Placed the plug around the wire by sliding the wire into the center of the plug using the slit. I did this as close to the hard plastic grommet that is attached to the o2 wires as possible. 3. Now take the slit plug with the wires in the middle, and just pop it back in place of the hole. --Now you can barely tell we even cut a slit in the body plug, and we didnt spend a dime, and the wires are now ran through the right sized body plug.--
12. Now you can put the carpet back in place, and start at step 6 and go backwards until you have everything back together as it was in the first place.
**Now go out and have fun, and have the peice of mind that you didnt have to cut any wires, or hack anything up....the most you had to do was unbolt some stuff, and cut a tiny little slit in a body plug. Oh YEah!!!---- you may have had to buy a plug to plug up the old hole that is not used no more.**
**If you feel i have left anything out or would like to add, then please please do!!** Thanks
"93civEJ1"
Old Apr 12, 2004 | 11:54 PM
LancerEvoMR's Avatar
Discuss thread here
xanderracing
24
Feb 14, 2024 12:14 PM
mrwickd123
Evo X How Tos / Installations
30
Feb 20, 2019 09:29 PM
robertg
62
Feb 18, 2016 03:28 PM
michiganevox
Mar 5, 2011 07:25 PM
vtluu
15
Feb 7, 2008 09:40 PM
