DIY tensioner tool
Old Jun 9, 2020 | 04:18 AM
Miomio's Avatar
DIY tensioner tool
So in preparation for a timing belt job I made this tool since I didn't buy one and took some pictures/measurements along the way.
Required stuff:
Some 3mm drill bits/pins of some sort
a piece of mild steel
a grinder
Welder is good to have
a drill
~13mm nut/bolt
Start by making a rough cardboard outline of your tool:
Trace it on a piece of steel:
I already drilled my holes for the pins.
The holes should be ~13mm apart
Grind a relief for the tensioner bolt.
and after some cleanup and grinding it to correct size:
Tack your pins in the holes
Note that you don't have to weld them if you don't have a welder. All you have to do is get them to stay in place with epoxy/whatever
Cut the pins flat, add some weld and grind them a bit nicer:
again you can just use epoxy or something if you don't have a welder.
For the tension nut/bolt you can either weld a nut in there or do what I did and drill and tap a bolt in there:
and from the other side:
Here are the final dimensions of my tool with some beautiful ms paint:
The pins protrude ~6mm on the other side.
Cheers :3
Old Jun 9, 2020 | 09:21 AM
colo_evo's Avatar
I made the rod portion using all thread but i couldn't justify spending time making that tool when i had this available for $10 on amazon.
Amazon Amazon
__pg
Mar 26, 2026 01:18 PM
lando524g
Jun 2, 2017 09:37 AM
xtruemassacre
10
Jan 29, 2013 01:43 PM
BLK REX
Oct 4, 2007 04:30 PM
wickdaddy
Lancer How Tos / Installations
Aug 14, 2007 06:40 AM
