Need Deals? Water/Meth Injection? Logic has it for ya!
We have started carrying the coolingmist injection kits. We have the single stage delux kit in stock starting at 239.00. These kits work with both water or methanol.
Click To Order
Comes with the following
Methanol Safe
90 Day Warranty
100 psi water pump
1 Electronic Solenoids WITH Brass Barb Fittings
15 feet OF high psi water hose
Hose Clamps
Zip Ties
1 adjustable boost pressure sensors
1 water injector nozzles
1 custom machined injector holders
1 fuse holder
relay Wiring Harness
30 AMP Relay
16 Gauge Wire
High END Arm / Disarm Rocker Switch(OEM STYLE)
Electrical Connectors
ON call live technical support
We have other kits available if your looking for a dual stage kit with two nozzle injectors.
Ready to ship out.
EVO Fuel pumps $85 Shipped or $97 Shipped with install kit.
HKS 272/272 Camshafts $550 Shipped fedex 3day
EVO -6AN Fuel Rail Fittings $19
AMS Red Fuel Rails $165
Turbosmart Boost Controller $69
GSC Camshafts $499 Shipped
Exedy Twin Plate Clutches 9 Available PM for The BEST price
Cat Delete Pipes EVO - $70 Shipped!
Greddy Profec Type S - $309 Shipped!
Other In Stock Specials Give us a Call at 877-564-4277
Thanks
Chris
Click To Order
Methanol Safe
90 Day Warranty
100 psi water pump
Hose Clamps
Zip Ties
1 fuse holder
30 AMP Relay
16 Gauge Wire
Ready to ship out.
Thanks
Chris
with the Delux Single Stage Kit for $239, you get a choice of many upgrades, such as clog nozzle detectors, upgrade, water filters, angled injectors, water tanks and more.
there are other kits available as well, the Deluxe Dual Stage Kit Performance Package is top of the line at $499.
The Dual stage kit offers the ability to run a small injector and a large injector in your car at two different locations of your intake track. The smaller injector runs a low boost, the larger injector runs at higher boost. Your intake temps will drop to ambient to near abient and most cars see power gains from just bolt on., includes:
Methanol Safe 90 Day Warranty on water injection kit
Lifetime warranty on the air temperature gauge
High Quality Digital Air Temp gauge and Sender Unit
Dual Stage Clogged Nozzle/water flow detectors
3 QT water tank
100 psi water pump
custom water filter
2 Electronic Solenoids with Brass Barb Fittings
over 30 feet of high psi water hose
Hose Clamps
Zip Ties
2 adjustable boost pressure sensors
2 water injector nozzles
2 custom machined injector holders
1 fuse holder
30 AMP Relay
16 Gauge Wire
High End Arm/Disarm Rocker Switch
LED
3 QT water tank
100 psi water pump
custom water filter
Hose Clamps
Zip Ties
1 fuse holder
30 AMP Relay
16 Gauge Wire
LED
I think he was asking about Denatured (Ethanol) Alcohol that is readily avail from hardware stores like Lowes/HomeDepot.
And this kit doesn't use stock washer bottle correct? Hmm where can I find space for a 3qrt tank. hmm...
it's a lot cheaper tho.. hmmm.
Chris
I have looked at this dozens of times but I am waiting for somebody to chime in regarding where/how they are mounting them in the '05 cars that do not have the intercooler sprayer. I would really like to get one of these systems but I have yet to see any comprehensive information regarding where to mount, where to tap, etc. Some more information would make it a lot easier to buy.
Technov
Technov
Originally Posted by mooreboost
Is there any way to hook this up to the stock intercooler sprayer resivoir?
Chris
Originally Posted by rlazer5000
Dammit Chris, ur gonna make me go broke! Are these things difficult to install? Thanks man!
Link to install pictures
Also the owner of the company that makes the kit is a great guy he is really knowledgeable and will answer any question you have if you call him up. His name is David.
Thanks
Chris
FS[SouthEast]: Snow performance Water/Meth Injection Kit
Kustom09art
Southeast Region
Oct 30, 2015 04:28 PM
IMPORTIMAGE
771
Mar 19, 2010 09:00 AM
4WS Tuning
29
Jul 16, 2008 10:34 PM
THmotorsports
57
Jun 4, 2008 03:22 PM
EvoTio
34
Feb 19, 2006 09:08 AM
