Sun Auto Hyper Force, Exedy HD/SD Twin Plate, 20G, TME, IX Turbochargers, and More!
Sun Auto Hyper Force System is now available thru Speed Element Performance!
Hyper Force System is the next generation High-efficiency ignition tuning and strengthening system.
Benefits:
1) Increased engine responses
2) Improved fuel efficiency
3) Improved starting ability
4) Increased Hp/Torque
5) Reliable Ignition Spark Throughout the entire rev range
6) Reduced emissions / Stabilized idling
How does it work?
Normal ignition coils inherently generate back electromotive force (Back EMF refers to a reverse flow of electricity from the coil immediately after ignition). This negatively affects the ignition device in the coil, decreases plug voltage, and negatively affects plug efficiency. Voltage becomes unstable and produces ignition time lag in the next ignition cycle. HYPER FORCE SYSTEM absorbs back EMF, to improve plug voltage and promote complete combustion through 100% coil efficiency. Hyper Force System also eliminates ignition Performance loss due to reduced electrical current under heavy throttle.
With improved ignition efficiency through the entire rev range, torque, acceleration responses, fuel efficiency, and complete combustion can be realized.
Complete Kit (including EVO specific harness) - MSRP $388, Please PM me for Best Pricing!! FREE SHIPPING!
WANT CLUTCH KITS? We Got Them Too!!!
Exedy Twin Plate HD - MM022HD - PM for Pricing! 8 sets
Exedy Twin Plate SD - MM022SD - PM for Pricing! 2 sets
Exedy Stage 1 - 05803 - $499 free shipping! 10 ses in stock!!
Exedy Stage 2 (4-puck) - 05952 - $595 free shipping! 10 sets in stock!!
Fidanza Flywheel - $425 free shipping!
Exedy Stg1 w/ Fidanza Flywheel Combo - $899 free shipping!
Exedy Stg2 w/ Fidanza Flywheel Combo - $999 free shipping!
Cosworth M2 Camshafts are now IN STOCK!!! We have 4 sets available!
Got a shipment of Cosworth High Lift camshafts for the EVO8 last week and they came with a spec sheet, so I just thought I would post them up so people could see the official specs direct from Cosworth. I don't have a direct test results yet, but they tell me that they were tested heavily on a larger GT series setup that made over 700 whp.
The duration measurement on these cams are actual, and if using the same advertised duration measurement like hks, they are closer to 280's.
Since these are high lift cams, upgraded valvesprings are required.
Introductory Offer: $600 Free Shipping!
JDM MR BOV $99 Shipped!!
HKS 280 cams $630 shipped! 1 set at this price!
HKS 272 cams $630 shipped! 3 set available!
FULL RACE Stock Replacement Manifold
$939 Free Shipping!!
FULL RACE Equal Length GT Turbo Manifold w/ 44mm WG flange $1250 Free shipping!
Full Race Equal Length Manifold w/ Garrett GT30R or GT35R Turbocharger and Downpipe or Full Race Stock Replacement Turbo Manifold w/ TME, EVO IX, or 20G turbo setup
Note: For Complete Kit, Please call!!
GT Series Manifold and Downpipe are made per order basis! For Info and Pricing, Please give us a call or shoot us a PM.
Garett GT30R .62 and .83 Turbochargers IN STOCK!!! Our insane Killer Price $1149 shipped!
Garett GT35R .82 Trim Turbocharger IN STOCK!! Our INSANE KILLER PRICE $1279 shipped!!!
Genuine Mitsubishi Single Port/Flap 10.5 Hotsides are now Back IN Stock!! $229 FREE SHIPPING! BLOW OUT PRICE! 1 WEEK ONLY!
Hallman Boost Controller Pro RX series! - $90 Free Shipping!!!
EVO 6.5 RS TME Turbocharger w/ 10.5 hotside - $729Free Shipping!
Specs: features a titanium aluminize shaft to reduce the shaft weight by an amazing 30%! Teamed w/ a much larger 10.5cm turbine housing, this turbo is capable to flow more air than stock EVO 8 turbo and with the lighter shaft, spool-up is much faster than with the stock EVO 8 unit! This is a direct, Mitsubishi made, replacement for your stock turbo to give you an extra boost of power!! Capable of 300+ awhp!
EVO IX Turbocharger w/ 10.5 hotside - $729 Free Shipping!!
Spec: features a revised 10.5 hotside, and the brand new EVO IX compressor housing. This compressor housing was designed to address issues with compressor surge as well as flow limitations found in the EVO VIII.
EVO IX Turbocharger w/ 10.5 hotside and Ti/Al turbine(TME setup), $1099 Free Shipping!!
Spec: In addition to regular EVO IX turbochargers, this setup comes with Titanium turbine blade and Aluminide cartridge for insane spool-up and response!!
EVO IX 20G Stage I Turbo - $929 Free Shipping!!!!!
EVO IX 20G Stage II Ti/Al setup Turbo - $1280 Free Shipping!!
Everything is IN STOCK and READY to SHIP!
Tanabe 2.75" Downpipes are now in stock!!
$249 shipped! 3 sets available!!
Apex'i WS NOIR Stealth Exhaust System - Complete cat-back systems!
Piping size: 75mm-80mm-100mm, $515 Free Shipping!!
Thank you!
Calvin
Benefits:
How does it work?
Thank you!
Calvin
