MIL.SPEC 65mm Throttle Body HOTNESS!!!
Old Dec 19, 2008 | 11:41 AM
  #241
Erik@MIL.SPEC's Avatar
MIL.SPEC, home of the
whistle-free
boost-leak free
non-sticking throttle plate
65mm throttle body.
If your ported unit displays any of the above characteristics, than consider a MIL.SPEC unit.
Plus, our TB's come with the TPS adjusted to Mitsubishi OEM specs and the throttle shaft is machined for additional flow.
Old Dec 31, 2008 | 02:31 PM
  #242
Aby@MIL.SPEC's Avatar
Happy New years
Old Dec 31, 2008 | 02:37 PM
  #243
nils's Avatar
yea.. happy NYE guys... !!
Old Jan 1, 2009 | 07:37 PM
  #244
ricksevo9's Avatar
how much to port the o2 and stock exhause manifold?
Old Jan 1, 2009 | 11:37 PM
  #245
DimitrisIX's Avatar
I installed my 65mm TB mil spec TB and it feels great. Throttle response and driveability have been improved a lot. Just by opening the TB a little with the throttle pedal gets the car moving. This helps a lot with larger than stock turbos. With a ball bearing red turbo and the stock TB it felt like it had some turbo lag in higher gears (compared to stock turbo). With the mil spec TB low end now feels better than the stock turbo. Also no idle problems at all.
Old Jan 7, 2009 | 11:19 AM
  #246
Glad to hear things are working well!
Old Jan 12, 2009 | 07:10 PM
  #247
bpclements's Avatar
I am interested in picking one of these up. I have a perfect core ready to go. Can you PM me some details on how to purchase?
Thanks,
Barry
Old Jan 14, 2009 | 07:48 PM
  #248
sorry for the delayed pm barry.
Old Jan 14, 2009 | 07:51 PM
  #249
evoixbri's Avatar
Did you have milspec ported intake mani as well, or are you talking about the ported TB with stock intake mani? I'm curious if it's worth it to do the intake mani with all the hassle that comes with it.
Old Jan 14, 2009 | 10:18 PM
  #250
^ iirc, he is running an AMS intake manifold.
Old Jan 15, 2009 | 10:31 AM
  #251
bpclements's Avatar
No problem. I will be ordering very soon. Thanks!
Old Jan 21, 2009 | 04:41 PM
  #252
bpclements's Avatar
Payment sent for 65mm TB! This should work great with my setup.
Old Jan 27, 2009 | 12:11 PM
  #253
1QYK9's Avatar
Happy New Year Aby!
What would the procedure be to get your 65mm TB from somebody other than your current installers? Can this item be purchased directly from you? I could do the de-install/install myself...simply need the modified TB.
Old Jan 27, 2009 | 12:47 PM
  #254
^ Yes, you can get a tb directly from me.
However you must increase the mani inlet opening to 65mm in order to get the most from the 65mm tb.
Old Jan 29, 2009 | 01:13 PM
  #255
Tracking numbers have been sent.
Thanks for the orders
