Unbeatable Pricing on the amazing Magnus Cast Intake Manifold from MAPerformance!
Old Dec 12, 2008, 09:05 AM
maperformance's Avatar
Click on the dyno charts above for a larger view.
(Left: Stock Turbo / Evo OEM vs Magnus Cast)
(Right: GT3037 Turbo / Evo OEM vs Magnus Cast)
Magnus Cast Aluminum Intake Manifold
Includes adapter to suit stock or 75mm+ throttle bodies / throttle body gasket / heat barrier gasket to head / hardware!
Over 10 years ago, Magnus Motorsports released its first Sheet Metal Intake Manifold into the market place and it quickly became the standard within the Mitsubishi Racing community. After almost 2 years in development, we would like to introduce you to the next big thing. The Magnus Motorsports Cast Intake Manifold.
Magnus designed this one from a fresh sheet of paper. Out of over a dozen prototypes, endless testing and perfecting, the Magnus Cast Intake Manifold was born. They applied our years of experience from crafting thousands of sheet metal intakes and once again have raised the bar for power and quick response. By applying a unique design and a massive 5L plenum, this cast manifold means big power and big power sooner!
Cast in A356 Aluminum with a wall thickness of 3/16"; the Plenum shape features a varying contoured tapered profile at a volume of 5 liters. The runners themselves are completely revolutionary in their design; featuring an integrated velocity stack that gradually transitions into the head port profile. It was designed entirely against the shape of the original cylinder head port taking advantage the 10° port entry of the EVO head maintaining un-interrupted laminar flow. The Magnus Cast Intake Manifold will work with throttle bodies from stock right up to 100mm and have seen consistent gains from 30 awHp to 52 awHp with varying setups. Transient boost response is exceptional and it can bolt together in a stock location if required while still being able to be used on a full blown race application.
Cast Intake Manifold Features:
  • 2 years of research and development
  • Cast from A356-T6 Aluminum Alloy
  • High quality casting gives a superior surface finish
  • Enhanced flow dynamics utilizing CAD Modeling & CFD simulation
  • Flowbenched and dynamically tested
  • Dynotested proven up to 50 HP / Stock turbo gains up to 40HP
  • Ability to flow 100 lb/min (1000 HP) of air at 60PSI while maintaining equal flow distribution
  • Can be installed in stock location with clearance for original battery (with adaptor)
  • 15 degree entry to the throttle body facilitates intercooler plumbing
  • Can be configured for 8 injector setup.
  • Fits factory fuel rail or Magnus high flow fuel rails
  • 5L plenum with contoured velocity stacks molded into the floor for huge top end and minimal turbulence
  • Magnus Quality and Lifetime warranty
maperformance is offline
Old Dec 12, 2008, 11:33 AM
ETS Michael's Avatar
Checked one out in person yesterday... Looks great!
ETS Michael is offline
Old Dec 12, 2008, 12:17 PM
Thanks for the input sir!
Old Dec 12, 2008, 04:04 PM
Bump.
Old Dec 13, 2008, 08:33 AM
Old Dec 13, 2008, 10:06 AM
darkside4G63's Avatar
price to 37167? also does this have EGR provisions? thanks
darkside4G63 is offline
Old Dec 13, 2008, 10:36 AM
Sorry, it does not have EGR provisions!
You have pm!
Old Dec 13, 2008, 02:59 PM
Bump.
Old Dec 14, 2008, 03:59 PM
browningderek's Avatar
quote on one shipped to 31788
browningderek is offline
Old Dec 15, 2008, 07:34 AM
Pm Sent !
Old Dec 15, 2008, 08:57 AM
Bump.
Old Dec 15, 2008, 04:16 PM
Bump to the Top.
Old Dec 16, 2008, 08:11 AM
Bump.
Old Dec 16, 2008, 03:49 PM
Bump.
Old Dec 17, 2008, 08:02 AM
Bump.
Quick Reply: Unbeatable Pricing on the amazing Magnus Cast Intake Manifold from MAPerformance!
