Torque Solution Engine Mounts, Shifter / Driveshaft Bushings, Exhaust Hangers!!!
Here is the full Torque Solution Lineup for your evo 8/9.. These are what we run our cars and are on every single car in our signature.. Please ask questions if you are unsure of what you will need for your car.. Thanks!!!
Mike
Torque Solution Exhaust Mount: Mitsubishi Evo VII-IX 03-07 (kit) 42.00 SHIPPED
The Torque Solution Exhaust Mount are a direct replacement for the stock pieces on all 2003+ Mitsubish Lancer EVO.
Torque Solution Shifter Cable Bushings:Evo VII-IX 03-07 5 spd 35.00 SHIPPED
This popular item is designed to replace the soft rubber bushing found at the end point of your shifter cable assembly. This upgraded bushing greatly improves the feel of the shifter by eliminating that spongy feel you get when changing gears. Easy to install with simple hand tools. Highly recommended when using our Short Throw Shifter.
Applications:
*5 speed
Torque Solution Shifter Cable Bushings:Evo 03-07 6 spd 35.00 Shipped
*6 Speed
Torque Solution Drive Shaft Carrier Bearing Support Bushings: Mitsubishi EVO 1-10 50.00 SHIPPED
Torque Solution Drive Shaft Center Support Bushings will replace the OEM Rubber mounts with billet aluminum pieces. Doing so will allow for reduced wheel hop, improved acceleration and better E.T's. The mounts keep the propeller shaft from moving under hard acceleration, stopping and turning giving you optimal performance 100% of the time out of your EVO.
These mounts fit all years 1992-2010
Mitsubishi EVO
EVO I
EVO II
EVO III
EVO IV
EVO V
EVO VI
EVO VII
EVO VIII
EVO IX
Evo X
Torque Solution Billet Aluminum 4 Piece Full Engine Mount Kit:Mitsubishi (5spd) Evo VII-IX 03-06 379.00 SHIPPED
The Torque Solution EVO motor mounts are made from high grade billet a aluminum material, polyurethane bushings, and steel pins. Here at Torque Solution our mounts are anodized black with torque solution laser engraved. These mounts can be seen on some of the fastest street and track EVO's in the world. These mounts have been tortured tested and proven to hold over 1000HP and 8sec 1/4 mile e.t's. These mounts bring world class performance to you for an affordable cost. Rest assured you are getting a mounts that will be reliable for years to come and help you win on race day!
Torque Solution Billet Aluminum 4 Piece Full Engine Mount Kit:Mitsubishi 6 Speed Evo VII-IX 03-06 379.00 SHIPPED
If you need only 1, 2 ,3 of the above parts from the mount kit we can separate just PM us with what you need
Mike
Applications:
*5 speed
*6 Speed
Mitsubishi EVO
EVO I
EVO II
EVO III
EVO IV
EVO V
EVO VI
EVO VII
EVO VIII
EVO IX
Evo X
hey are these still avaliable? im after the 4 piece engine mount kit, shifter bushings and Drive Shaft Carrier Bearing Support Bushings for 6 speed evo 9 please thanks
I know this is an old thread but very curious as to interior dash vibrations and other noises as a result of using this product. Are there any problems with vibrations by the use of this product? I am currently using an Ingall dampner however the fire wall vibrations has become unbearable.
Shaun@AWDMotorsports
AWD Motorsports - Florida
73
Jun 14, 2016 10:33 AM
EvoX 'For Sale' External Engine / Power
197
Jun 14, 2016 10:26 AM
AWD Motorsports
293
Jun 14, 2016 10:25 AM
EvoX 'For Sale' Suspension / Brakes / Handling
227
Jun 14, 2016 10:23 AM
Nov 2, 2015 09:15 AM
