help with the Craighardy panel!!!
Old Dec 6, 2004 | 05:17 PM
djmikeymike's Avatar
I just installed the CH panel the other day. I love the look of the panel in the day time but at night when i have my lights on, light comes out around the knobs and the buttens. Does anyone have the same problem? is there any way of fixing this? at night it looks like a cheep install i must fix this. thanks for the help!!
Old Dec 6, 2004 | 05:20 PM
wingnut17's Avatar
you could take the panel back off, and putting a rubber "weather stripping" around the hole where the knobs would go in. you could put the rubber on the inside of the panel so it wouldn't be seen. and then put the panel back on and put the knobs on and you wouldn't be able to see any light coming out. I don't have the panel but its just the first and best idea to come to my mind.
Old Dec 6, 2004 | 05:32 PM
i was thinking about makeing a HomeDepo run. thanks for the idea
Old Dec 6, 2004 | 05:35 PM
denial's Avatar
Please post to let us know how it goes. If it works out well I might have to try it too.
Old Dec 6, 2004 | 05:36 PM
do you have the same problem^^^^^
Old Dec 6, 2004 | 05:41 PM
denial's Avatar
Yep, pretty much the same. Mine isn't quite as pronounced as yours is on the directional vent knob, but it looks almost identical to mine on the temperature knob. I also have a little bit of light poking through around the center buttons. It does'nt look horrible, but it'd be much nicer if I could get it to look like OEM.
Old Dec 6, 2004 | 05:49 PM
im gonna fix it.....i don't know how yet.... but it will be done
Old Dec 6, 2004 | 05:54 PM
denial's Avatar
well if you find something that works please post. I'll get around to fiddling with it later in the week.
Old Dec 6, 2004 | 05:55 PM
GreedMOTO's Avatar
I took a black permanant marker and went arount the inside edge where it was Dremeled down. That solved most of the light issues for me and it didn't cost a thing.
please do the same
Old Dec 6, 2004 | 05:58 PM
thanks.... i was think of starting out the say way, then adding something to the back of the panel if that didn't do the trick.
bigd31388
33
Aug 20, 2012 07:59 AM
shrty10135
Jun 26, 2010 02:26 PM
thedru13
Oct 23, 2009 07:10 PM
bigd31388
Lancer How Tos / Installations
Dec 2, 2007 12:22 PM
cautiontext
Lancer Troubleshooting
Jun 2, 2004 05:48 AM
