put in new head unit but have a problem.
Old Jun 25, 2010 | 07:44 PM
shrty10135's Avatar
Ok Before i installed this head unit the a/c unit was lighting up at night but now after the install today at night when you turn your lights on the a/c light doesnt not come on and i cant see the a/c panel at night. I dont know if its a coinsidence or i just havent noticed it yet because i havent driven it at night but the mph gauge is black and the rpm gauge is half light up. HELP!
Old Jun 25, 2010 | 07:57 PM
mogace's Avatar
Ok, first thing, Check fuses...Probably isn't a fuse, but it never hurts to check. Put your OEM radio back in and see if the problem continues.
I'm not firmiliar with clarion, but I'm pretty sure it has RCA sticking out the back of it, make sure the metal on the rca connections aren't touching anything.
IMPORTANT: on the harness, there should me atleast an Orange wire, and my an orange wire with a stripe in it. If you connected them, make sure you have connected them correctly. I've seen some companies switch up what those different colors mean. One is illumination, one is dimmer....It is not the same.
Old Jun 25, 2010 | 07:58 PM
mogace's Avatar
Hey, if you have any more problems or technical questions, PM me. if you have pics you can PM me that'd help too.
My info: I'm MECP certified and work full time as an installer.
Old Jun 25, 2010 | 08:05 PM
shrty10135's Avatar
Thank you, yes i hooked up orange to orange for illumination i thought maybe i should just disconnect it and see if it still is out
Old Jun 25, 2010 | 08:18 PM
shrty10135's Avatar
just checked both ornage wires are illumation wires. IDK what else it could be.
Old Jun 25, 2010 | 11:36 PM
mogace's Avatar
Have you plugged the OEM radio back in? Try plugging it back in and seeing if the problem keeps up. If you don't care, disconnect and cap off the ends. Can you PM me a pic of the "behind the dash"? I'm a visual person. (watch it be something easy that when you take the pics we both are gonna look at it and go "Ohhhhh yeahhhhh"lol)
Old Jun 26, 2010 | 10:08 AM
shrty10135's Avatar
i had a clarion system in there and i took it out and put this clarion in because of the need for in dash gps, i hooked up all the wires the same the only thing that wasnt hooked up before and i hooked up this time is the illumination wire.
Old Jun 26, 2010 | 11:21 AM
nelale2's Avatar
im having the same issue, and i know all my connections are correct. the only thing that i left out was the wire that ran along the antenna wire. Could this be my problem and your problem?
Old Jun 26, 2010 | 12:17 PM
shrty10135's Avatar
i left out the wire thats purple with white stripe (really long) and i grounded the parking brake wire (green) the only thing different is i hooked up the illumination this time and i know there both illumination
Old Jun 26, 2010 | 02:26 PM
shrty10135's Avatar
FIXED IT, i just punched the havc unit and the light came on! so it was just a coincidence but i still Got to change my gauge cluster bulbs i ordered from STM today.
E46byeRAhi
17
May 19, 2017 04:26 PM
alex3dworld
Evo X How Tos / Installations
84
Apr 21, 2016 08:36 PM
mrwickd123
Sep 13, 2014 11:44 AM
ibarkovic
Jul 10, 2008 06:31 PM
cdavy
Apr 19, 2006 05:51 PM
