Seibon CF Hood clear coat cracking
Old May 10, 2005 | 05:13 PM
BSREVOLUTION's Avatar
I just noticed my 6-7month old hood is cracking near the vents. I will try to get pictures soon. Im alittle pissed off. I didn't think I would have a problem like this so soon. I waxed the hood once a month. The cracks look like a defect. Anyone have this problem? Thanks justin
Old May 10, 2005 | 05:25 PM
lil'evil_evo's Avatar
thanks for the fyi, waiting for pic's
Old May 10, 2005 | 05:49 PM
scott88vr6's Avatar
Did you put any heat tape on the underside to prevent the heat from getting to it? My buddies is doing the same thing, but it looks like it is from the heat coming through the vent.
Old May 10, 2005 | 05:52 PM
eve-slow's Avatar
I have a seibon TSII cf hood that is cracking near the vents as well. Although I have a custom paint/clear job over the original clear/resin. Maybe the original clear has cracked all the way through to my top coat clear? It seems unlikely, but possible. Please post pics.
Old May 10, 2005 | 05:54 PM
en1gma19's Avatar
Damn I just saw this thread and looked at mine and found two tiny cracks as well.
Old May 10, 2005 | 06:13 PM
scott88vr6's Avatar
^^^I would suggest some heat tape on the underside.
Old May 10, 2005 | 06:23 PM
UndieStainz's Avatar
Do you guys (with crack,... , that sounds funny heheheh) have the rainguard under the heat grill installed? That might help with the escaping heat, etc. ...just a thought. Tell Derek at Seibon about this. I QT'd a latch and fit issue for them for the past week.
Old May 10, 2005 | 11:30 PM
i didnt have the rain plate on the hood. ill try to get pics asap. justin
Old Jan 9, 2006 | 06:47 PM
EVORyan's Avatar
My hood is cracked too in about 6 spots, it three months old. This pisses the hell out of me, and Seibon said they will not do anything about. At least I know what company not to recommend for carbon fiber parts, and now I know another product line not to carry for my company so I don't have to deal with unhappy customers.
Old Jan 9, 2006 | 07:01 PM
S2Kstephen's Avatar
Join the club guys...Our motors/manifolds put off ALOT of heat and its the cause for your cracking. I've had mine for 4 months, and it started real bad once the weather got cold.
To prevent it:
-Keep your car inside/garage...as warm as possible. When you do take it outside, hopefully the hood will be "warm" and the cold won't cause it to crack
- Apply some heat tape to the underside, around the edge of the vent(s).
Seibon won't deal with it. Its not worthy it anyway...buy the time you pay shipping both ways, you could just buy a new one.
Keep the OEM hood for best results
Old Jan 9, 2006 | 07:03 PM
AdamJ39's Avatar
Doesnt DEI make some sort of heat tape..?
-Adam
Old Jan 9, 2006 | 07:07 PM
Sxhawnn's Avatar
Originally Posted by AdamJ39
Doesnt DEI make some sort of heat tape..? i have the rainguard on... anyone know where i can get some heat tape? How much should i throw on there btw? 3 or 4 layers? Does it help if you put more layers on?
-Adam
Just bought a seibon hood.... i have the rain guard on..... i will be applying heat tape asap. Thanks for the heads up guys.
Old Jan 9, 2006 | 08:18 PM
imajinmyfx's Avatar
i have a seibon hood.. it cracks by the vents because its the weakest spot on the hood. heat also plays a factor too
Old Jan 9, 2006 | 08:23 PM
Sxhawnn's Avatar
is there anyone who has a seibon hood that doesn't crack?
Old Jan 9, 2006 | 08:31 PM
imajinmyfx's Avatar
im assuming these cracks arent hairline cracks? and its cracking on the corner of the vents?
most cracks are cause by applying pressure to the hood.. ex.. closing ur hood. i know you guys dont slam it down but there could be times where u might have pressed down on the hood a little too much
