Evo9 Front Bumper effects on Aftermarket IC?
Since the bumper's ic opening appears to be optimized for stock ic, do you guys think it will have a huge effect on a bigger aftermarket intercooler's airflow?
Originally Posted by ArchieBabes
I have the Greddy IC no problem at all
[/IMG]
Originally Posted by unowned
Your IC still extends behind the bumper to the sides which do not get airflow wasting the point of having a larger width intercooler
It will still cool down the incoming hot air better than the stock one
why spend 800-900 just to lose efficency of a larger intercooler though, the only adv is the core is probably a bit deeper, otherwise the surface area is almost the same as stock.
Because with a larger intercooler I can safely run more boost on the stock turbo. I'm running Alcohol Injection, boosting 26psi the result is 380whp on the stock 9.8 03 turbo
how much power would that be if you had an 05 turbo??
GST Racer
Mar 28, 2009 10:52 AM
svt1.8t
Jan 9, 2009 11:52 AM
NocturnalEVO
Jan 31, 2006 09:45 PM
TwStDeVo
Sep 16, 2005 09:40 AM
