5v power source in engine bay
Old Mar 6, 2006 | 11:28 AM
silex's Avatar
Looking to hook up my map sensor and it needs a 5 volt reference. I heard the tps sensor uses 5v but I can't locate it. Can somebody point me int he right direction of where I can find a 5v source?
Old Mar 6, 2006 | 12:48 PM
I'mStock's Avatar
EVO Show & Shine
Old Mar 6, 2006 | 02:43 PM
silex's Avatar
Whoops sorry about that. Never asked an electrical related question, but thanks mod for pointing me in the right direction . There has to be somebody that knows where I can find a 5v source in the engine bay.
Old Mar 6, 2006 | 09:04 PM
WHTEVO's Avatar
Get your multimeter and check your maf plug. Almost certain there is a switched 4-5v power source there. Good luck.
Old Mar 6, 2006 | 10:50 PM
Bexa20's Avatar
If you cannot find it use 12V make a small loop with the bulb, put your DVM in between the wire and the bulb and measure the current. From there use the Ohms law
V=I*R
Voltage = Current * Resistance
Since you are looking for the right resistor your equation will look like this
R=V/I
You know your V = 12V, and you will know your current by measuring it. Divide one by the other and you will know what kind of resistor to put in to get 5V. You will need to put the resistor in series.
Old Mar 7, 2006 | 11:24 AM
silex's Avatar
Bulb? DVM? Not sure what you mean with those two things, but I'd rather not fiddle with resistors on a 12v since they might jiggle off and plus expell heat. The last thing I want to do is have my map sensor fail which is the primary source of my boost monitoring.
I'm so newb. Where is the maf plug located in the engine bay? I think it's attached to the intake side? I need a constant 5v and I'm afraid a 405v switch might cause some problems.
Old Mar 7, 2006 | 12:06 PM
GTVEVO's Avatar
The stock MAF and MAP sensor are both 5v sensors.
Old Mar 7, 2006 | 08:46 PM
silex's Avatar
Oh wow sweet! Appreciate the 'for sure' response GTV!
Keng_v
Cobb AccessPORT
May 15, 2016 11:41 AM
acamus
Lancer Troubleshooting
Apr 16, 2008 11:15 PM
Ludikraut
18
Dec 26, 2007 01:30 PM
logic
Nov 17, 2007 12:48 PM
phil_
Oct 25, 2006 06:32 AM
