Removing Wing
Old Aug 28, 2006 | 01:58 PM
Eveolicious's Avatar
Removing Wing
Well, after searching: "Taking Wing Off", "Removing Wing" "Wing", "Trunk"... I couldn't find anything about taking the wing off.. and it seems to me there should be stuff out there...maybe I just didn't search the right term?
However... how is the process to take the wing off? Is it a pain? What has to be done?
Old Aug 28, 2006 | 02:03 PM
jhanksevo's Avatar
ok man it is easy all you have to do is open the trunk. remove the two rubber pieces on both sides of the lid and u will see a nut remove those two nuts and then if u look further down there are 2 more nuts but no rubbe just the nuts and remove them 2. U will have 2 bolts that remain. close the trunk and be careful but pull the wing viola!!!
Old Aug 28, 2006 | 02:06 PM
phenaly's Avatar
A little bit of heat for the double sided tape works as well!
Old Aug 28, 2006 | 02:26 PM
What did u guys use to cover the holes? I have a white car... so...
Old Aug 28, 2006 | 02:27 PM
prest0's Avatar
heat and an xacto knife, pulling could warp metal or tear paint a bit.
Old Aug 28, 2006 | 02:33 PM
Vivid Racing's Avatar
OK you grab the wing with two hands, put your feet on the bumper the yank really quickly! That should do it if your not stealing it then pop the trunk and follow the above written instructions... Best of luck!
Old Aug 28, 2006 | 02:40 PM
nObject's Avatar
white electrical tape works but watch out I left mine on for a couple of months and I pulled off some little pieces of paint when I took the tape off
Old Aug 28, 2006 | 03:15 PM
So then there really isn't anything thats "good" to use to cover the holes?
Old Aug 28, 2006 | 03:16 PM
jhanksevo's Avatar
i used painters tape that wont peel clear coat
Old Aug 28, 2006 | 03:18 PM
Or you can trade an 06 EVO RS for his trunk?? Like me i would trade for trunk and wing
Old Aug 28, 2006 | 03:20 PM
What colors does painters tape come in? I don't think I've ever seen a white painters tape...
Old Aug 28, 2006 | 03:21 PM
fraser91084's Avatar
i got my holes welded over and repainted. costs about 300 bucks
Old Aug 28, 2006 | 03:22 PM
Yea, well I may wanna put my wing back on in the future, so I don't think that'd be a good idea for me.
Old Aug 28, 2006 | 03:24 PM
sesso's Avatar
i just traded a dude with an ES for his trunk.. so i have no holes
Old Aug 28, 2006 | 03:25 PM
before that i went to a sign shop and got some gloss finish vinyl. it costs like a dollar a foot so it's a really cheap way to have something that from 3 feet you can't even tell is there
