****Nokya bulb users click here******
Old Sep 30, 2006 | 12:45 AM
revvin9k's Avatar
Well, I went out with a buddy of mine tonight and noticed that one of my fog lights were out. So being the obsessive compulsive type, I pulled over and went to take a look. What I found was quite odd and a first for me. The one on the right is the one that was out. I removed the other one just to make sure, and sure enough, the same thing.
Anybody else have this happen to them? I would check just to make sure, it would be a major PITA to have to take off the bumper and housing to clean out pieces of broken glass inside of it. I'm going back to PIAA.
Old Sep 30, 2006 | 01:07 AM
EVOLUTION Vlll's Avatar
its probably b/c of the watt they use... thank god that didnt melt ur socket..
im using piaa h11 u can get em in ebay for 40 bucks..=)
Old Sep 30, 2006 | 01:22 AM
revvin9k's Avatar
They are stock "wattage" bulbs. I also had the PIAA's prior to these and never had an issue like this.
Old Sep 30, 2006 | 02:42 AM
they are not stock wattage u should check nokya box again...
they run like 80 wattage stock is 55w
on the box it says 55=>80
Old Sep 30, 2006 | 02:46 AM
andyktlee's Avatar
Pocket Mo
Luminics makes some very good bulbs. I had the bulbs in my rsx for 4+ years and it didn't burn out at all. I even transferred the H11 Luminics yellow ion bulbs from the rsx to the Evo and it's still going strong. Not bad for $30 with an unconditional defect guarantee. They'll just be in until I order my XenonDepot Phillips yellow HID bulbs though.
Old Sep 30, 2006 | 02:48 AM
aboh6leenz's Avatar
i think that happens when you touch it or get oil on the bulb, because the place I bought mine from told me specifically not to touch the bulb while installing. He said it could make the bulb explode. Mine are still fine though and I have had them for a while.
Old Sep 30, 2006 | 07:15 AM
LoCo4's Avatar
Wow! I bought some 55W Hoen bulbs...still work great.
Old Sep 30, 2006 | 07:20 AM
4Gsixty3's Avatar
if it says 55->80W, then its utilize 55W and produce a brightness of a 80W. So u should be fine with it.... maybe its just a defective set u got. I use Piaa Plasma yellow, looks and works great!!
Old Sep 30, 2006 | 08:31 AM
JoeyM3's Avatar
wow crazy, ill have to check on mine
Old Sep 30, 2006 | 08:34 AM
BANKS 2's Avatar
looks like you/someone touched the bulbs with your fingers when you installed them.. the natural oils on your hands makes a HOT SPOT and cooks the lens when it heats up.
Old Sep 30, 2006 | 08:36 AM
~EVILEVO~'s Avatar
I Think someone touched them as well
Old Sep 30, 2006 | 09:33 AM
evoviiiyou's Avatar
I just got some of these in artic white, and no problems after 2 nights of cruising and running them for at least 2 hours straight. Here is the link.
https://www.evolutionm.net/forums/sh...d.php?t=225848
Old Sep 30, 2006 | 11:29 AM
revvin9k's Avatar
I have installed more bulbs and wired more HID systems in my time to know better to touch the bulb. I reassure all of you this was not the case. Just make sure you keep an eye on these bulbs periodically if you are running them.
Bill
Old Sep 30, 2006 | 12:00 PM
GPTourer's Avatar
That's true, that's what the PIAA's I have say on their box (actually 55w-->110) , and that's why I haven't had any problems with them yet.
However, the Nokya's are straight up 80watts which is too much and why I passed on them.
Old Sep 30, 2006 | 12:35 PM
its saying just 80W..
