Carbon Fiber Trunk
Old Oct 1, 2006 | 01:33 PM
The442GTO's Avatar
Carbon Fiber Trunk
I just put on my Seibon CF trunk and the trunk spring is very powerful and wiping up the trunk. I am scared that it might damage it. What have you guys been doing about that? Thanks Tony
Old Oct 1, 2006 | 01:52 PM
03evo4g63's Avatar
I know what you mean. i hardly use mine anymore. I'd like suggestions too.
Old Oct 1, 2006 | 01:59 PM
shadowist's Avatar
dont think there is much you could do. either you take out the tension rods or leave it.
there are 2 types of tension rods that come on the evo tho. theres a separate one for the RS and a stronger one for the gsr/mr due to the wing. you could try and source an RS one from a dealer.
if anything, the wing weighs it down a lot so it doesnt just snap open. what i used to do is just have someone wait and catch the trunk.
Old Oct 1, 2006 | 02:00 PM
Importedmex's Avatar
cant u like loosen up the tension on the spring or w/e...idk i dont have an evo but my moms neon has like extra holes to it so u can add or take off tension...idk hope it helps sumhow...lol
Old Oct 1, 2006 | 02:02 PM
S2myEvo's Avatar
yea i have the same problem dude!
iono what to do..
it doesnt really bother me that much.
u get used to it
Old Oct 1, 2006 | 02:04 PM
shadowist's Avatar
there is no spring in the evo trunk. i understand what youre saying though, i dont think there are places in our trunks to adjust it.
Old Oct 1, 2006 | 02:35 PM
chaotichoax's Avatar
I'm unsure haven't checked yet but in my STi I had a pair of tension bars. The trick was just remove one and you'd be fine. I can't confirm it is the same for evos though. They would be located towards the top back of the trunk.
Old Oct 1, 2006 | 02:50 PM
BigBallin's Avatar
what you need to do is buy these http://cgi.ebay.com/ebaymotors/2003-...1226QQtcZphoto and install them on your trunk. it has been done before and works great. they have to differnt designs.
Old Oct 1, 2006 | 05:46 PM
Matthew333's Avatar
take one of the rods out- if it is still too tight, you can heat it with a welding torch, and bend it 45 deg.
Old Oct 1, 2006 | 08:50 PM
The442GTO's Avatar
Hey Guys,
Ya I just took one of the rods out it was a Bi*ch, but it works fine now!
Old Oct 1, 2006 | 09:32 PM
03evo4g63's Avatar
Originally Posted by The442GTO
Hey Guys,
where are these located and how hard are they to remove. I might be doing this tomorrow if it really works.
Old Oct 1, 2006 | 09:51 PM
ForgivenEvo's Avatar
The tension rods are located in the trunk and under the speaker section of the trunk. There will be two black rods going across each other.
Can someone post a DIY on how to take one tension rod off?
Old Sep 28, 2008 | 02:18 PM
truDriver's Avatar
Channel locks make moving the tension rod pretty easy.
Old Sep 28, 2008 | 02:32 PM
sharkm87's Avatar
and u are 2 years late
Old Sep 28, 2008 | 02:37 PM
legal-z's Avatar
great find on this thread. i just swapped trunks today and was having the same problem.
