Old Apr 4, 2007 | 12:08 AM
  #631
NocturnalEVO's Avatar
^^^^ not without some major fender rolling in the rear.
the front im not sure about.
Old Apr 4, 2007 | 04:44 AM
  #632
Curt941's Avatar
Would 17x9 +22 all around fit if the rear fenders were rolled?
Old Apr 4, 2007 | 09:35 AM
  #633
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Originally Posted by projekt_shocker
so its true that you cant go with the same offset with the front and the rear... how much can u go with the front and rear wheels?
i am thinking about getting +22 offset all around... is that okay or no?
If you want to strech the tire no problem. IF you want to run 265s on it, then you'll have to shave a pull.
Old Apr 4, 2007 | 09:50 AM
  #634
xepyt's Avatar
That sounds feasible maybe in the front (at a very high stance), but not in the back.
I've seen 2 cars running this setup (17x9 +22 TE37s) one of them had GarageHRS fenders in the front and Voltex in the Rear, the other car was on stock fenders but stock ride height. I think he was planning on lowering the car after rolling the fenders. This was the set-up I was going to get
Old Apr 4, 2007 | 10:07 AM
  #635
Curt941's Avatar
So how can people run 18x9.5 +20 offset Work Emotion CR Kai's with no modification whatsoever? But 9" wide with +22 offset won't work?
By my math, the 9" wide wheel should be sticking out 8.35mm LESS than the 9.5" wide wheel with 20mm offset
And what about the silver EVO with white TE37's, 18x9.5 +12 in the front and 18x10.5 +22 in the rear, with no wide fenders or anything?
Old Apr 4, 2007 | 10:13 AM
  #636
that silver evo w/the te37's tires are super stretched.
Old Apr 4, 2007 | 10:27 AM
  #637
broeli's Avatar
You have to understand that it will all depend on tire brand and size, as well as ride height, as to what will fit and what needs rolled, etc. It also depends on how hard it is driven. Sure you might not get rub on some of them cruising around on the street...but take it to the track and push it HARD on a car that is substantially lower and you'll be more limited as to what will work and what won't. I run 285/30 Hoosiers and there is NO WAY a +24 would work in the rear. If I had a stretched 255 tire and didn't race then it would. I THOUGHT I had no issues in the front until I pushed it hard in testing and got rub on my front lip edge...so I even had to roll up the front fender lips. Some make it sound easy to fit big wheels..it's not. After one autox I ran into another issue. I rubbed through the front fender liner into some sheetmetal causing a small cut on my tires. Now I have to take a hammer to that area. It wouldn't be an issue on a car that is just driven on the street though. Everyone needs to keep these things in mind. If you're going to push your Evo hard and run the proper 265+ tire that you should on a 9.5" rim be careful with what you choose.
Old Apr 4, 2007 | 11:06 AM
  #638
DarksideEng's Avatar
You would need to roll the rear fenders to run the 18x9.5 +20 Emotions. 18x9 +22 will work easier. The thing is the offset is what determines where the tire sits. The tire is the thing that would rub, not the wheel, obviously. So with the same size tire , call it a 255/35, on the 9" and the 9.5", the 9 +22 would be 2mm safer than the +20. But since the tire would be more stretched on the 9.5", it would be easier to fit. Now if you used a smaller width tire on the 9" +22, it would fit even better.
Old Apr 4, 2007 | 11:23 AM
  #639
cnoevo8's Avatar
who said that?????????
Old Apr 4, 2007 | 11:29 AM
  #640
Curt941's Avatar
It seems like from what i've read you can, I think the only thing maybe needed was rolling the rear fenders.
There are pictures of a GG evo with those wheels on it.
Old Apr 4, 2007 | 11:48 AM
  #641
M3this's Avatar
See page 1 of this thread
BTW the guy is running 255/35/18 BFGs on them
Old Apr 5, 2007 | 01:54 PM
  #642
cnoevo8's Avatar
nowhere in the 1st page does it say you can run work cr kai's 18x9.5 w/o any modification at all that is just silly. look at how much those tires stick out of the rear fender of this GG.
I am refering to the post that said no modification at all.
F.Y.I. I have talked to jim at work USA, he knows the guy who ownes the gg w/ the 18x9.5" +20 cr kai's. He said he mounted the wheels, drove it out into the parking lot and took pix of it. That's it!
If you want these wheels, you will have to be willing to do the following:
1.roll or shave the rears within 1/16 of their life.
2. pull out the front fenders just a little bit.
3. adjust the camber on the rear.
I shold know, I will have these wheels and thats what I will have to do to get them to fit without rubbing at all (for the most part)
Old Apr 5, 2007 | 02:02 PM
  #643
Curt941's Avatar
Do you have pictures of your car? I'd love to see the wheels on another car as well
Old Apr 5, 2007 | 06:09 PM
  #644
A-SPEC's Avatar
I shold know, I have these wheels and thats what I had to do to get them to fit without rubbing at all (for the most part)
Thank you for your post!!
I CANNOT stress this enough. Although you CAN run these wheels on the Evo, it WILL take A LOT of work.
Just to clarify for those that are looking for these wheels....PLEASE don't think this is a bolt-on option. If you're gangstar enough, by all means...but if not, PLEASE look for another fitment
This is basically the same setup that you would run on a 350Z rear, or an S14. On an Evo.....pretty mextastic.
Francis@aspec
Old Apr 5, 2007 | 06:11 PM
  #645
A-SPEC's Avatar
Another good point is that if you run a smaller tire like a 245/40/18, it helps as the extreme stretch of the sidewall will give you the angle you need to help clear the fender.
Francis@aspec
