Engine bay cleaning q's
Old Apr 7, 2007 | 04:09 AM
Jspec EVO VIII's Avatar
So springs finally here and i want to do a complete wash of my ride inside and out. Wondering what you guys use to clean the engine bay with. Any suggestions? It'd really help, thanks.
Old Apr 7, 2007 | 07:06 AM
BBS's Avatar
BBS
Simple green. then use some wd-40 to give it alil shine.
Old Apr 7, 2007 | 07:07 AM
1320 Engineering's Avatar
spray in some degreaser and pressure wash it out.
Old Apr 7, 2007 | 07:11 AM
jhanksevo's Avatar
+1
Old Apr 7, 2007 | 03:33 PM
ries's Avatar
take out the battery first!!!
then degrease and spray/rinse w/ water...
Old Apr 7, 2007 | 03:47 PM
idriveanevo's Avatar
make sure your sparkplug holes dont get water in them, mine did, big problem
Old Apr 7, 2007 | 03:52 PM
wizzo 8's Avatar
I use shout. It works great. Spray it on let it sit for a couple of min then hose it off with very light water pressure. Then air dry
Old Apr 7, 2007 | 03:55 PM
EvoEntropy's Avatar
WD-40 workjs well
but +++1 to what everyone else said
great advice
Old Apr 8, 2007 | 02:03 AM
Thanks for the responses, going to do the wash on my next day off
Old Apr 8, 2007 | 12:52 PM
bttkcooled's Avatar
I just washed mine today... what a PITA!
Old Apr 10, 2007 | 05:19 PM
RRRS's Avatar
+1 on removing the battery. you can also use aluminum foil to cover the electrical stuff. also, its not a good idea to leave solvents or wd40 on rubbers too long. my cousin the crazy car detailer uses some kind of of engine bay cleaner that he sprays all over the place, wont harm rubber/plastic and gets everything shiny as new.
Old Apr 10, 2007 | 06:14 PM
I-Dom-In-8's Avatar
Simple green to clean everything up.
Aerospace 303 to shine everything up.
Old Apr 10, 2007 | 07:52 PM
IceXpert's Avatar
Any before/after pics with the products mentioned?
Old Apr 10, 2007 | 08:46 PM
TempeRacerGuy's Avatar
I would pass on the simple green if you have anything polished. I used simple green on my MR2 with polished cam cover/intercooler piping, and it corroded everything pretty quick.
The best is a steam pressure washer with a light detergent. Just be sure not to get the spark plug hole soaking.
Old Apr 10, 2007 | 08:48 PM
Blue Evo 8's Avatar
Another thing to do is to take some aluminum foil and wrap up the spark plug cables and the alternator.... you dont want to get those wet...
I use compressed air to blow dry my motor after a wash
