HID Conversion not working :(
Old Jun 4, 2007 | 01:06 AM
Adamk24's Avatar
Yeah so I picked up an HID conversion kit for my 05 GSR, came with ballasts, bulbs and wiring. Plug and play kit, not really anything to be messed up as far as installation, the connectors only go on one way.
Basically I hooked just the new hardware up (and the other bulbs) but the headlight and its hardware all still off the car getting painted. I tried this for a 'test run'. When I have the stock low beams in, all lights function normally. With the HID kit swapped in the low beams place, all the stock stuff works (turns, high beams etc) but the low beam HID's don’t come on.
Is there a relay or a fuse or anything that needs to be upgraded for these to work? Instructions aren’t specific but they just say its plug and play. Also note that the stock fuse (10 or 15 amps or something) is not blown.
Thanks for any help guys
Old Jun 4, 2007 | 01:08 AM
JohnEB's Avatar
Had this problem on 2 kits, reverse the plugs and try it
Old Jun 4, 2007 | 05:32 AM
Adamk24's Avatar
Hmm they have the connectors as such that I can only plug them in one way. I'll try swapping some lines and see what I get. The diagram does say red and black to the box, but red and black are coming out of the box.
Old Jun 4, 2007 | 05:50 AM
NoTec's Avatar
I never did like generic plug and play hid kits. I always went with the oem stuff. Post picks of what you did if you can.
Old Jun 4, 2007 | 05:52 AM
Adamk24's Avatar
I'll see if I can find my camera. I just did a DOVM voltage test. I have power fine coming from the stock connector. It hooks up to a new set of wires from the kit and those wires hook into the ballast. The wires test fine, but testing the output wires from the ballast show no voltage.
So whatever is going on, there is a problem with the ballast not sending voltage to the bulb. I'm going to contact the manufacturer, see what they say.
Old Jun 4, 2007 | 08:52 AM
boostin@27's Avatar
i had same problem
Old Jun 4, 2007 | 09:14 AM
camMCLEAN's Avatar
same problem. cut and flip the connectors. guarenteed they will fire right up.
Old Jun 4, 2007 | 04:01 PM
Adamk24's Avatar
which connectors should I flip the red/black power leads going to the bulb coming from the ballast?
Old Jun 4, 2007 | 04:34 PM
Adamk24's Avatar
Ok so rather than waiting for a responce I just went and tried to flip one set of the wires coming out of ballast and still nothing. Any suggestions?
Old Jun 4, 2007 | 08:16 PM
Adamk24's Avatar
Bump for help, seems like allot of people have problems with these kits. Any suggestions on what I need to swap or rewire?
Old Jun 4, 2007 | 09:39 PM
Adamk24's Avatar
Ok I got this working now. What a total PITA!!!!
Basically the kit had one connector that attached to the stock plug in, then had 1 large rubber/plastic wire that lead from there to the ballast. I had to strip off the rubber shell and swap the two wires inside then re-solder them. Looks like junk but it will do the trick.
Thanks for the help guys.
iJHolmes
Feb 28, 2012 02:25 PM
howmuch4onerib
Apr 3, 2007 06:33 PM
g-lo
13
Mar 17, 2007 10:28 PM
autodoodad.com
109
Jan 24, 2007 11:12 AM
donduck
Lancer Troubleshooting
Sep 5, 2006 02:22 PM
