APR Front Splitter install (the right way)
Old Jan 14, 2008 | 09:52 AM
  #46
evokel's Avatar
^looks good
Old Jan 24, 2008 | 10:55 PM
  #47
Dave2's Avatar
Originally Posted by Mulholland0132
wtf are you talking about??? The rod isn't creating some dramatic support to keep this splitter on the car. The bolts all around the bumper and into the center bracket under the engine (attached to the frame) is what keeps this thing in place. I was posting about the washers needed to give extra support in all these various mounting locations. The rods just keep the splitter pulled to an upward angle. Why would they break off easy unless the whole splitter was pulled right off the frame
I sure hope your wrong.
i have the same splitter 2 years ago, the rod will break very easy when you going up/down to a slope than scratch/bent the splitter. I'm not saying it will break due to down force. I broke mine rod few times already and i just leave it without the rods.
Old Jan 24, 2008 | 10:58 PM
  #48
Dave2's Avatar
Originally Posted by EVOla_VIRUS
the rod wont break off easy but your mom is a different story
oh.. very funny e-thug
Old Jan 25, 2008 | 12:36 AM
  #49
fastkevin's Avatar
So to start let me thank Jeff from 500whp.com for an awesome price on this splitter shipped to my door.
I went to dude's website to check it out, and came across this description of a wing.
"Feeding back the aerodynamic technology of Ings where it is born with the circuit, forges and can make a foolish mistake is Z-POWER WING. Clearing the topic which is required from the street car which of course, weight and the finish, called the beauty of the forum which generates optimum down fourth durability and quality at high level. With stage of all running, enjoyment of driving is assisted. "
Anyone translate?
I couldn't find your on there..
What'd the splitter set you back?
Old May 2, 2010 | 01:59 AM
  #50
Evo8ux2's Avatar
ok i installed mine today but the two holes that bolt up under the engine are no where near close, anybody else have this issue?
Old Feb 20, 2011 | 02:57 PM
  #51
evoiao's Avatar
apr splitter poor fit
mine didn't fit at all the instructions say 2006-2007 I have a 2006 ix so you'd think it would fit! on one half, the splitter holes lined up perfectly, but then the other half was not even close. Even if the holes did line up the whole splitter was not centered, meaning that it was flush on one side of the car, but again the other side stuck out at least one inch.....argggggggggggggg....any suggestion to make this fit properly???? my undertray fits perfectly so I just dont understant why the ARP splitter does not fit correctly....do I need to re-drill the holes in the proper place?
Old Feb 20, 2011 | 03:46 PM
  #52
vipers's Avatar
^^ the splitter is supposed to stick out of each side around a 1/2 inch.. it is not supposed to be flush with the bumper... and all of the ones i have seen fit great!
Old Feb 21, 2011 | 08:02 AM
  #53
evoiao's Avatar
that my be true but it not very helpful, since the fact remains that one side IS flush using the existing holes.....so how do you account for that? I'm looking for help and would like to get someone advise that can help me fix the problem.
Old Feb 21, 2011 | 09:56 PM
  #54
chaotichoax's Avatar
do you have a standard ix lip or an se lip?
Old Feb 22, 2011 | 07:52 AM
  #55
evoiao's Avatar
se lip....but the under tray fit so the holes line with that?
Old Feb 22, 2011 | 03:09 PM
  #56
Evolento's Avatar
line it up with the bumper off the car then drill on the holes of the SE lip
Old Feb 22, 2011 | 03:42 PM
  #57
if your SE lip did not come with your evo...you are missing to brackets that are needed to mate the SE lip to the APR splitter.
part # - 6512a151
part # - 6512a152
They are needed to reuse the stock undertray with the SE lip. They rivet to the lip and have mounting holes for the undetray. They are also needed for use with an APR windsplitter unless you want to drill holes.
on mitsubishiparts.net they are $30.99 ea
Old Feb 22, 2011 | 03:50 PM
  #58
wildacuario's Avatar
nice looking splitter but i had to remove it, because it was too heavy for my stock lip...had to replace the stock lip for the cf ralliart style (two support that hold the lip were broken) and i was afraid to hit the pavement damaging the front bumper because i lower the evo .
Old Feb 23, 2011 | 09:08 PM
  #59
evoiao's Avatar
this is what I'll do thanks
thanks very much this is what I'm going to do!
Old Feb 23, 2011 | 09:59 PM
  #60
S14Swap240sx's Avatar
omg so amazing.. wish i could swing this
