to trim or not to trim
Old Jan 15, 2008 | 01:15 PM
  #31
SlowSportSedan's Avatar
you can never have too much trim....
Old Jan 15, 2008 | 02:43 PM
  #32
CBRD's Avatar
[QUOTE=Normanruben;5157432]
Originally Posted by braille
I've spoken to Cal at Speedelement about this dilemma that i had and he explained to me that the risk of trimming the fender lip is that it loses some of its integrity. CBRD, do you notice this problem with cutting the fenders? Does the fender become weaker? On the other hand, if you roll your fenders, you will notice a slight bulge near the bumper mounts that are located on the fender. I admit i am a perfectionist and i can notice every conspicuous detail on my car. So after giving it some thought, here's what my conscious mind came up with. If i decided to trim the fender lip, i would trim it and reinforce the fender with two, maybe three layers of composite fiber (kevlar/carbon weave or carbon weave or structural fiberglass) with a medium hardness epoxy resin on the inside panel of the fender. That way i the section would have mild strength while maintaining flexibility. I noticed this is what Subaru did (BTW, my subaru is my dd) in my GC8. There is a ~4"X10" piece of hard material that is adhered to the inside of the quarter panel to give it strength. I can snap some pictures if you are interested.
Mike[/QUOTE
please do. that is what i was worried also by trimming, the integrity of the fender. you got a pretty good idea on reinforcing the fender. thanks.
we have no issue, we still leave both layers overlapped, so they are strong as can be...
cb
Old Jan 15, 2008 | 02:49 PM
  #33
EVOlution561's Avatar
Roll them if you want them to look good.
Old Jan 15, 2008 | 02:50 PM
  #34
CBRD's Avatar
lol...
they look no different when trimmed, actually i think they look better, and we dont have the creasing problem...
but do what you are comfortable with.
cb
Old Jan 15, 2008 | 06:55 PM
  #35
blacksj's Avatar
Roll them
Old Jan 15, 2008 | 08:03 PM
  #36
Tarmacisback69's Avatar
I do collision work for a living and i do believe 200 is alot for labor, considering all your probaly doing is taking a piece of 36 grit on a grinder then using sum type of undercoating to prevent rust. it probaly takes you no more then hour.
Old Jan 15, 2008 | 08:11 PM
  #37
CBRD's Avatar
ok,
our hourly labor is 100.00..
my main tech did body work for almost 2 years..
we use a cutting disc, after taping the line on the fenders etc... then covering the outside as explained before... we then smooth everything with an angle grinder.. prep it with solution... cut the tab off of the inside of the rear bumper, then re-rivet it, to act as a clip... then we spray the underbody..
it takes just about 2 hours.. we arent the cheapest, but we've never had our clients say we are too expensive for the quality of our work...
do what you all feel is right, we made our recommendation
cheers
cb
Old Jan 15, 2008 | 08:21 PM
  #38
dtmpower647's Avatar
roll em
Old Jan 15, 2008 | 08:24 PM
  #39
Normanruben's Avatar
what kind of underbody protectant do you recommend? thanks.
Old Jan 15, 2008 | 09:07 PM
  #40
CBRD's Avatar
there are a few different kinds, ill check with my tech tomorrow...
dont just get the inexpensive 3m stuff... we usually get it from a local paint supply shop.
cb
Old Jan 15, 2008 | 09:38 PM
  #41
eponti's Avatar
If you decided to roll your fenders have the pro do it or you will crack the paint.
Old Jan 16, 2008 | 10:56 PM
  #42
Cali2MDevo8's Avatar
Registered User
Originally Posted by CBRD
ok,
cheers
cb
Don't forget the part where you climb into the back seat and Mark drives to see if they are shaved enough!!!
Old May 7, 2008 | 05:30 PM
  #43
Trueno86's Avatar
Sorry to bring this back from the dead.
Question for CBRD.... after trimming the fenders, do you guys keep the fender liner? I already have my fenders rolled but it's still rubbing. So I am considering removing the liner as well.
Also, Would you recommend doing that for the front too? If I rip out my liner in front, it will expose all kinds of stuff behind it such as the oil cooler, IC spray reservior.. etc.
Thanks!
tsidrift1
For Sale - Part Outs
Apr 14, 2017 08:32 AM
nicolassabra
Sep 19, 2013 04:02 AM
Immaculate
Apr 13, 2011 12:49 PM
JakeTheVIII
Dec 9, 2009 06:18 PM
lcakes05
Nov 12, 2006 03:07 PM
