C-West body kit question
Old May 29, 2008 | 01:31 PM
lilman8403's Avatar
Question C-West body kit question
I recently bought a new c-west kit and i have a few questions regarding the front bumper. I belive i had to remove the bumper beam however there are two holes on the under side above the intercooler on each side. It seems like these two hole would line up with the factory bolt holes but since i removed the beam they are not there. Also, where the bumper meets the bottom of the headlight, there is a fin piece that comes out and there is not slot for it to slide into. Do i just cut that off or does it indeed go somewhere? My civic has a similar slot and there is a slip on the headlight bracket it slides into to hold it up against the headlight.
Any thoughts, comments, or suggestions would be helpful!!!
One more thing, i was wonder if any one has put led license plate light on the c-west rear bumper and if you have which one did you go with?
I read about the tabs under the headlight and it seems like i can make that work but i would rather have as little gap as possible. Aside from the top bolts and two side bolts, is that it? No center bolts?
Old May 29, 2008 | 01:48 PM
vi3txdr34m5's Avatar
i have the whole kit lol no Slit on the front but i left it there ?? i dont know why mine is genuine um rear bumper u have to make your own or pull the stock rear pieces out
Old May 30, 2008 | 11:11 AM
lilman8403's Avatar
So does everyone who has this bumper have a small gap below the headlight is it just a hit or miss thing?
Old May 31, 2008 | 08:34 PM
Vostok 7's Avatar
The gap below the headlight is pretty common. How big it is is all up to how good your body guy is
This is what mine looks like, I've been told it's one of the smallest gaps seen.
- Patrick
Old Jun 1, 2008 | 07:24 PM
lilman8403's Avatar
thank you that does look nice!
EvoCats2011
Apr 23, 2009 04:51 PM
timmyx1
Oct 7, 2008 12:41 AM
HassounEVO
Jun 30, 2008 04:55 PM
Evo11V
Mar 9, 2008 06:06 PM
rraulston
Jan 31, 2007 09:36 PM
