JDM Headlight Projectors
Old May 22, 2009 | 08:07 AM
evo2809's Avatar
Question JDM Headlight Projectors
Hello!
I'm fixing an EVO with Salvage title, I bought a set of JDM Headlights,
but I'm not sure which is the ballast that the projectors use, could you help me to find the part number?
I have seen some in ebay like this:
That is the ballast that I need to my projectors work?
Thanks!
Old May 22, 2009 | 08:55 AM
donmeca2020's Avatar
doesnt matter what ballast you use, unless you want that straight "JDM" theme i have MR 8 NON HID headlights and i threw a set of aftermarket HIDS and they have been working good for the last 3 years with no problems
Old May 22, 2009 | 09:26 AM
evo2809's Avatar
Ohh that sounds good, then if I buy a set of aftermarket HIDs ballast, my projectors lights will work, and about the foglights and the other light?
is the same?, sorry but is the first time that I will use EVO lights since I
buy the car without ones
Old May 22, 2009 | 09:30 AM
only thing being you wont be able i think to mount the ballasts under the headlight it will have to be mounted elsewhere in the engine bay
Old May 22, 2009 | 09:37 AM
evo2809's Avatar
I was confused, I think the JDM Headlights are not HID, then if I don't use a HID ballast the projectors and the other bulbs will work good, if I want to have HID light then I need the HID ballast.
Now is better
Old May 22, 2009 | 09:38 AM
evo2809's Avatar
But what kind of bulb use the projectors?
Old May 22, 2009 | 09:39 AM
GPTourer's Avatar
If bulbs came with the projectors you bought then they most likely won't work with an aftermarket kit. I believe donmeca is suggesting you buy a complete aftermarket kit that comes with its own bulbs and ballasts, which he has mounted in projectors that came in a non-HID halogen equipped Evo.
Old May 22, 2009 | 09:41 AM
evo2809's Avatar
Ohh I see, thanks!
Old May 22, 2009 | 09:44 AM
GPTourer's Avatar
But if you go that route, they probably won't be as good as the stock HIDs and you won't have the leveling feature.
tsitalon1
28
May 4, 2015 12:42 PM
blackandredgts
13
Jan 7, 2014 09:14 AM
GdotRegEvo9
Feb 20, 2010 11:15 AM
athmak15
Lancer Troubleshooting
38
Jan 14, 2009 12:22 PM
w8lifter21
Feb 11, 2008 08:53 AM
