Operation Revival 2003 Evo 8
Old Feb 13, 2010 | 05:47 PM
  #46
letMeIn's Avatar
front way too low
Old Feb 15, 2010 | 09:38 AM
  #47
MurphDurph's Avatar
nice job man...ive been followin on your thread since the 4g63 swap did you completely scrap that project or will you finish it? i ask cause i will be attempting the same swap soon and wanted a few pointers/advice on what i look forward to. you can pm me so i dont jack this thread
Old Feb 15, 2010 | 09:46 AM
  #48
MaD_CaNaBiCe's Avatar
thanks man I never bothered with the lancer being that the chassis was so rusted and I have big plans for the evo so having the 2 of them as projects will be very expensive and pointless.
I will PM you my messenger so if you need to know anything hit me up I can give you a few ideas and what you will need based on the experience i've had with my lancer.
Old Apr 1, 2010 | 05:25 PM
  #49
Ok guys well the car spun a connecting rod beaing so I deceide to use it to my advantage and it was time for a rebuild also the car had bad third gear synchros and decided to change the 4th gear synchro also thanks to www.jackstransmission.com even though I havn't received them yet usps international shipping is really slow but anyways got the crank installed lastnight and planning to finnish assembling the motor tommorrow morning.Looking to get 500whp when I get my wideband,cams and upgrade my turbo kit
Took the tranny to work and put it in our high powered parts cleaner
then sprayed it with about 2 coats of high temp paint and 3 coats of high temp clear coat came out looking fresh and new.
manley crank and acl main bearings installed weighing 31lbs best my mechaic has been very experienced with building all kinds of evos says this is a much better crank than the eagle crank which is almost the same price
few other goodies I ordered from www.extremepsi.com whose customer service is platinum
Old Apr 2, 2010 | 02:49 PM
  #50
well got the bottom end all fitted up this morning and put back in the car.I decided to wait for the synchros I ordered from jackstransmissions to put the gearbox back together and bolt it to the engine before I blot on the head.
This must have been a printing error noticed this after I purcahsed the parts and was worrying they would not work but all of my parts are standard bore
Old Oct 28, 2010 | 04:13 PM
  #51
So anyways havn't updated this thread in months due to engine failure. So just 1100 miles after installing the manley pistons,rods and crank my oil pump failed and screwed up my crank and block so I needed a short block to get my car back on the road after days of searching with no results that fit my budget a friend of mine told me about a evo 5 that is in driving condition and selling for below 2k so ofcourse I jumped on the deal and got alot of nice goodies along with it the pics will tell the tale.
Here is my boy engineer who used to work for mynes perfomance in arizona taking the motor out of the evo 5 which is now his being that I never wanted to get caught up in another project.
[IMG]http://i258.photobucket.com/albums/hh249/mad_canabice/My%20Evo/DSCN4123.jpg
[/IMG]
Motor out of the evo 5 already being torn apart and getting ready to put in my car
Evo 5 shortblock with stock crank balanced,Je pistons,eagle H beam rods,King main bearings and clevite rod bearings installed with my evo 8 head.
Installed a carbonfiber hood,trunk and a different front bumper hadn't painted it yet since I am waiting for my evo 9 rear bumper.
Got my tripple pod installed with aem tru boost and aem 0-150 psi oil pressure gauge.
Got some hood damper from my friends mitsubishi GTO planning to install them sometime next week.
Old Oct 28, 2010 | 11:03 PM
  #52
Evokid8's Avatar
man talk about working on everything outdoors lol straight up island style!
Old Oct 29, 2010 | 09:38 AM
  #53
lmao we only took the parts outdoors for pics this time it was done in the shop
Old Jul 8, 2011 | 05:53 PM
  #54
WoW It has been a long time since I have did some updates to this thread and I have been through alot of drama with this car that I have not even documented but to make a long story short the car has come a long way since I purchased it 2 years ago an here is how it stands today, Just a few more things performace wise I would like to upgrade then I would like to paint the car and leave it the way it is since I am not far from my HP goal of 700 hp.
Here is an evo 6 head I had laying around my yard that I sent to jamaica to get port and polished by AC Enineering who did a spectacular job
Specs are
Supertech 1mm oversize Intake valves
Supertech 1mm oversize Exhaust Valves
Supertech valve guides and valve seals
Ac Engineering 3 angle Valve job
Gsc S2 Camshafts
Gsc Behive Valve springs
Fidanza Cam Gears
Intake Port
Exhaust Port
Precision Gt30R turbo kit which I blew and the race meet we had last month
Oh well the next day I got a sweet deal on a 6262 which is what I wanted from the start but the GT30R made me do a 7.666 on 20 psi with pump gas and street tires on the 1/8th here
Precision 6262
Precision GT30R
Also got a new Set of shoes. Konig 18x9.5 in the rear and 18x8 with a 1" spacer in the front. yes they are staggered because they were for my friends S15 silvia
Did a little cleanup of the interior looks 100 times better than when I got it
Got the Aem in December last year and finally got the e-prom fixed whius was a pain in the a$$
Old Jul 8, 2011 | 06:05 PM
  #55
Also Upgraded from the exedy twin disc to a spec mini twin disc with the Push style conversion.
Removed the resonator from my HKS Hi power exhaust.
Buschur 65mm Throttle body
Precision 880cc injectors
custom 3" intercooler piping
Old Jul 9, 2011 | 08:56 AM
  #56
BOOSTINAT30PSI's Avatar
Looks good bro
okevolutionVIII
Aug 3, 2016 12:06 AM
MaD_CaNaBiCe
13
Feb 6, 2016 06:11 AM
MaD_CaNaBiCe
May 24, 2012 07:17 AM
antevo7
Jun 23, 2010 09:12 AM
Adam@MMS
Jun 1, 2010 11:44 PM
