Just another DIM (Did It Myself) tailight coversion
i tried that and one of the light bulb housings turned slightly oval and almost became impossible to fix. needless to say the project was immediately cancelled.sucks cause i really wanted to do it. are the headlights easier?
OT. Hey turbotime sup man? how is the project is comming along?
Thanks alot guys. Yeah the headlights are easier to do one you heat them it's just a matter of prying them open. Evo72man once you as long as you put them in the oven at 250 degrees and I never leave mine longer than 5 mins you should be ok if you don't wanna risk it use a dremel I am sure it will make it easier but if you use a sheetrock knife like I did and do it with the glue hard there is a chance you will crack the lens.
MaD_CaNaBiCe
Jan 6, 2008 07:26 AM
