is this bad???
Old Nov 14, 2003 | 07:43 AM
Boston'sEvO-->8's Avatar
is this bad???
ok ok i was racing last night against an 03 cobra moded, a 02 z06 moded, and a 350z moded. The first race on the highway it was me the z06 and the cobra I have a Works ecu reflash and thats all. We all down-geared I was actually up till the end of 4th...lol then they pulled on me in when i went to 5th. Then I pulled up next to the 350z I was in 3rd we both got on it and when I went to put it into 4th the car just shot straight up to 9 grand for a second and i let off but after that the car was driving fine any suggestions on what happened or should I be worried and get my car checked out???
Old Nov 14, 2003 | 07:44 AM
boostedwrx's Avatar
Learn how to let off the gas when you clutch in. Other than that dont worry about it if your not going to be messin your shift up every day.
Old Nov 14, 2003 | 07:45 AM
DJPhattRoc's Avatar
possibly sounds like a clutch if it was reving high, and then dropped
Old Nov 14, 2003 | 07:47 AM
Dale_K's Avatar
As long as you had it in the right gear you should be OK. If you accidently shifted into 2nd instead of 4th you might have really overreved it. The Works reflash raises the rev limit but doesn't eliminate it, as I understand it. So theoretically you could just put your foot to the floor and the motor would never go beyond whatever the new Works rev limit is. If you put it in the wrong gear and let out the clutch there's nothing the rev limiter can do to prevent sky high revs and possibly a blown motor.
Old Nov 14, 2003 | 07:48 AM
Dont get me wrong im a good driver I did a 13.2 @ 105 at new england dragway....The only thing im thinking of is if the car went into second without me realizing it thats what has me worried and the fact that my car didnt hit the revlimiter at 7800 and it hit 9000
Old Nov 14, 2003 | 07:50 AM
Dale if I did put into second and anything happened to the motor i would realize it right away right it wouldnt be a slow process do u think I got lucky this time around or should I have someone check it.
Corey's Avatar
don't know what could be the problem with your car, but there is no way you stayed ahead of a 03' Cobra and a Z06 on the highway with just a WORKS reflash. I owned a 03' Cobra and I don't see it happening. Ecspecially with a modded on at that.
Old Nov 14, 2003 | 07:52 AM
Dude dont start there is no way thing because i did stay up with them and the z06 does 11's with NOS and the cobra's trap speeds are around 120mph and they are my friends. So the evo has alot of sack and it was cold last night and i dont bull **** but i started this thread so i can find out info on my car if its ok not to back up if my car realy did keep up so if u dont believe me i dont care but what i do care about is the car.
Old Nov 14, 2003 | 08:07 AM
Diesel's Avatar
this isn't a Show and Sine topic to begin with... this should be in the 2fast2furious forum...
racing on the highway...? smart...
Old Nov 14, 2003 | 08:19 AM
SuPaNooK's Avatar
you couldve accidently shifted into 2nd without noticing and avoided blowing your motor by takin it out real quick..you car should be fine but take note that its possbile some internals coulda gotten messed up but just not showing yet..
Old Nov 14, 2003 | 08:29 AM
2fast2Furious's Avatar
In Timeout
Alright now, keep my name outa this
Old Nov 14, 2003 | 08:35 AM
Dale_K's Avatar
It would probably be catastrophic and immediate, in other words the motor would have blown up. So you're probably OK. You could make sure your oil pressure is normal. You could also pull the oil filter and cut it open to see if there are any metal particles. But I think you lucked out.
Old Nov 14, 2003 | 04:39 PM
Corey's Avatar
I'm not starting anything. Just going by experience with both cars you wouldn't stand a chance on the highway with either cars mentioned above with your one mod. I guess your buddies suck at driving.
As for your car....sounds to me you put it in 2nd gear. I did that to my ITR and bent some valves, but you would know by the time you slow down because the car wouldn't idle for **** and probalby die on you if they were bent bad enough. I'm gonna say your car is prolly okay.
Old Nov 14, 2003 | 04:46 PM
EvoRider36's Avatar
Im gonna say your car is ok too. My best friend also did the same thing in his ITR, twice!!! ANd both times he bent his valves and had to have his car towed. I think you would have been alerted right away if something went wrong inside the motor. You would have heard an extremely loud pop, at least thats what I know from having friends with that experience. Just chalk it up to experience and watch those shifts more carefully.
Old Nov 14, 2003 | 08:15 PM
GotBoost25psi's Avatar
