New headunit/hvac set up!
Old Dec 19, 2013 | 09:24 AM
  #181
GTB/ZR-1's Avatar
Originally Posted by cyanide
The "surround" part is additional, and its purpose is to give it the recessed look as if it was the actual hvac surround from the factory trim.
Thank you, looks like it may be my quickest solution right now.
Old Dec 19, 2013 | 09:28 AM
  #182
cyanide's Avatar
No problem. If you need instructions to relocate the controls and install a 2 din with the oem 2 din trim, let me know. I'll email them to you.
Take care.
Old Dec 19, 2013 | 09:54 AM
  #183
InsanePain143's Avatar
I installed the Eden kit. It works great but the price is a little high. It saved some head ache though so it was worth it to me.
Old Dec 19, 2013 | 12:44 PM
  #184
nirvancol's Avatar
How do the cover plates attach? Do you have any pictures from during the install?
Old Dec 20, 2013 | 03:10 PM
  #185
The plate attaches like the original bezel, just 2 screws. I used two smaller screw to make it fit a little easier. The plate sandwiches the MR cubby between the climate control and plate. the second plate just attaches with some 3M sticky tape. It just covers up the edge of the temp, mode, and blower speed stickers. It's really simple.
Attached Thumbnails New headunit/hvac set up!-cam00166-1-.jpg
Old Dec 21, 2013 | 10:31 AM
  #186
nirvancol's Avatar
Ah ok. Thanks for the pic. So the only purpose of the taped on plate is to hide the edges of the stickers? I'm thinking it would look better without the extra plate
Old Dec 22, 2013 | 07:04 AM
  #187
Honestly there isn't much of a noticeable difference with or with out the second plate. I just put it on because I still had it. I didn't really think that the two screws was enough to support the climate control but it's actually pretty sturdy.
Old Jan 3, 2014 | 04:00 PM
  #188
GTB/ZR-1's Avatar
I just ordered the Eden unit for my MR--now what do I do w/ factory gauges? lol
Old Jan 8, 2014 | 08:25 AM
  #189
Kaizen Tuning's Avatar
Here are the ones I used to make (sorry no longer making them)
-Jason
Old Jan 11, 2014 | 08:16 PM
  #190
Kelzendless's Avatar
Nice and clean
Old Jan 11, 2014 | 08:40 PM
  #191
KiiD2X's Avatar
I bought one of these. They are awesome. I will load a better picture of the actual kit during the day, but I've had it installed for 3 months now. One thing though my hvac lights don't work on one side and some times not at all. Anyone see that before? Ima check the bulbs I just never got around to it.
Attached Thumbnails New headunit/hvac set up!-image.jpg
Old Jan 12, 2014 | 04:11 AM
  #192
cyanide's Avatar
Hi. If it's only half the bulbs that are turning on, you should check your fuses first. I had this happen with both Lancers I had, 02 and 05, and it was a blown fuse, but I don't remember which one. Turn your lights on and check the rest of your bulbs. If it's the fuse, there should be other bulbs also off outside. The fuse should be from the engine compartment box, but check both just in case.
If all fuses are good, then you'll need to test by swapping the working bulbs to the non working side.
Hope this helps.
Old Jan 13, 2014 | 04:44 PM
  #193
bighead87's Avatar
How can I buy 1 of those relocation kits I want to instal a 2din in my Evo 8 but I need 1 of those relocation kits like the 1 above looks real clean where can I get my hands on 1
Old Jan 15, 2014 | 03:44 PM
  #194
Gabe900's Avatar
deleted
Old Jan 15, 2014 | 07:46 PM
  #195
GTB/ZR-1's Avatar
Here' the Eden kit--as stated, pricey, but looks OEM. It ended up being worth it to me.
