"JUNK BOX" Complete!! 8s???
LOL not sure why the shop your car was worked on would even consider a stock plug in a set like that. Or even tried to tune through that smh. Are you even running a cop ignition set up??
I feel that statement was pretty negative towards SM, take that else where man.
Lol , No negativity whatsoever fan boy , just a simple question. common sense is authorized.
Beautiful car none the less, and Ive said it already best of luck in your goals!
You can say its common sense, but i know AMS was running stock heat range plugs awhile ago. None the less, they know its the plugs and it will be back soon.
You should probably get to know SM and Devin before you start saying things like that. Those cats have built some fast cars and they know what they're doing! I'm sure there's more to the story.
You went to go try your best at 8's with the stock plugs installed Joey??? Madness!
Instead of going with crazy expensive plugs, I'd get some copper plugs and keep a few extra sets around.
You need that detail to make 'JUNK BOX' as smooth as glass for her maiden 8 second voyage! Less wind resistance!
GL!
GL!
i clean and wax this car too much. Sunday i buffed the whole car before the track, i dont think anyone does that hahaThanks dude! Will know more tomorrow on whats going on.
That is the plug the car was started and broken in on for a couple hundred miles. Obvisouly we wouldn't throw a stock heat range plug in a car capable of 700+ hp for tuning..
Yea it was a bummer but plan to go this weekend if everything works out!
