STM's Project "Ultimate Street Evo?"
Yes, It will run to a catch can from there.
A lot of time was spent on this one as well as the one we used in Shawna's 8.
-Em
-Em
When I get a chance to test it I will let you guys know how it works. At that point I can supply all the parts for the kit. I will tell you this though, To run the kit the same way as us you will need to buy the Buschur Brake booster delete as our lines are made to use with that.
-Em
Emery if you are interested I have a bolt in plate/template made for the staging brake and a nice way to do the cable attachment. Since you guys are making stuff for us now in the way of CNC'd parts/flanges etc. if you want to copy this template I can send it over.
Sure, I have no problem taking a look at what you have. Might be able to make a nice little kit out of it all.
-Em
I'm running the Buschur kit, It can be found here. https://secure.buschurracing.com/cat...3b0e7e8f403265
-Em
-Em
-Em
It uses a different master cylinder that retains the feed for the clutch slave and the brake switch light. It also comes with the CNC'd mounting plate STM makes for us and the brake line/fitting kit we supply. You will need a good quality brake pad upgrade too.
