need help!! paint overspray
Old Jan 20, 2004 | 01:55 PM
NYEVO8's Avatar
Unhappy need help!! paint overspray
ok boys and girls i just got my front bumper repainted, do to some chips and people cant park hits. i asked the body shop to remove my bumper and take the car outside of the work area when he painted. now if he did or not who knows. i got some paint overspray on my windows and head lights, does anybody know of some liquid that wont harm the plastic lenses of the lights and clean the overspray off windows also.
thanks for any sugestions.
Old Jan 20, 2004 | 01:56 PM
osunick's Avatar
I would take it back to the shop... not only do they owe you an explanation, they should also have the stuff they need to fix their mess.
Old Jan 20, 2004 | 01:57 PM
NYEVO8's Avatar
just to add he did detail the outside of the car so there is no overspray on the body itself.
Bluto's Avatar
Use clay bar.
Old Jan 20, 2004 | 01:58 PM
NYEVO8's Avatar
yeah you are right but my friend took it there when i was away this week, and i have basically zero time free to go there right now.
Old Jan 20, 2004 | 01:59 PM
NYEVO8's Avatar
Originally posted by Bluto
Use clay bar.
will that work on the plastic lenses and glass? i thought it was for painted areas only.
Old Jan 20, 2004 | 02:08 PM
psionic98's Avatar
on glass you can use a razor blade if you have the time to sit there and do it, or there is a rubbing compound that is for windows and stuff... look in your pep boys or whatnot in the aisle with the windshield wiper blades etc... as for the plastic.. maybe goo gone? shouldnt harm the plastic I dont think, but I never tried
Old Jan 20, 2004 | 04:44 PM
kuniboy's Avatar
Clay magic! you'll be suprised!
Old Jan 20, 2004 | 05:52 PM
jerzepnoy's Avatar
use nail polish remover .. make sure u only do it to the windows and headlights.. thats what i did when i spray painted and a gust of wind blew it on my rear window.... or when i had eyelids and the paint behind it wasnt dry and i placed them on my lights
Old Jan 20, 2004 | 08:33 PM
NYEVO8's Avatar
thanks everybody
Old Jan 21, 2004 | 08:03 AM
NYEVO8's Avatar
any other ideas before i start with the clay and nail polish remover. i did use a razor on my front window with a ton of windex got most of it off but just worried about the lights.
Old Jan 21, 2004 | 10:10 AM
SinCityEvo's Avatar
clay bar, clay bar, clay bar. Guaranteed.
Old Jan 21, 2004 | 10:17 AM
number 8's Avatar
Had the same problem with over spray on rear window. Took it back to body shop. He used that clay bar and it scratched the f#@* out of the window. Needs a very light touch. So watch it!
Old Jan 21, 2004 | 10:20 AM
Secret Chimp's Avatar
Skip the nail polish remover. You don't want to risk having that polish/paint remover drip/spray/rub against the painted surfaces of your car. And depending on the chemicals in the remover, it will damage the plastic surface of the headlight covers.
Use a clay bar. It'll take the paint right off the lenses without damaging the plastic.
If you have a hard time getting the paint off the glass with the clay, you can rub VERY gently with quadruple 'x' steel wool. This is the finest grain steel wool available. I used this to remove the old overspray from the windows of my 61 Mini and it worked wonderfully. Just make sure you have 'xxxx', and that you rub very gently. Rubbing hard, or using the wrong grade of steel wool will end up in a finely scratched glass surface...
SC~
Old Jan 21, 2004 | 12:52 PM
wmcorcor's Avatar
clay bar!
JJVeld
Feb 4, 2017 08:09 AM
Evosick2332
Midwest Region
Jan 11, 2010 11:05 PM
B350
Jan 31, 2009 07:11 AM
kreionic
May 7, 2007 03:34 PM
