What glue to re-attach IX front lip mount tabs?
Old May 7, 2012 | 10:52 AM
hokiruu's Avatar
On my OEM IX front lip a few of the mounting tabs that the screws go into snapped off. Not a single plastic piece broken into two, but looks like it's an actual separate piece from the lip that Mitsubishi somehow attached to the bumper. I'm sure some how you know what I mean. I tried using cement for plastic plumbing pipes and that worked for a day until it just peeled off the lip in a sheet again leaving me back at square one.
Anyone have any ideas? This is my fourth OEM lip and I don't want to wate more money on them.
Old May 7, 2012 | 10:55 AM
sujinX's Avatar
gorilla glue?
if those adhesives dont work, plastic weld or bondo is the only other thing i can think of.
Old May 7, 2012 | 10:57 AM
hokiruu's Avatar
Plastic weld may be the solution. Thanks
Old May 7, 2012 | 11:19 AM
tsidrift1's Avatar
Same thing Happened to mine. I used a 2 part plastic epoxy that you can get from any home improvement store. Rough the surfaces up with some 36grit sandpaper too. Just helps the bonding.
Old May 7, 2012 | 01:43 PM
hokiruu's Avatar
Thanks, I'll try that.
Old May 7, 2012 | 02:35 PM
evo2nv79's Avatar
If you can get your hands on it, try Henkel Hysol 9309.
That stuff is strong, and also hard to get.
If you or you know someone that works in aircraft, that's where you can get it.
Old May 7, 2012 | 04:06 PM
bcrance13's Avatar
I tried epoxy on the tabs you speak of, because I hit a stupid raccoon 2 weeks after getting a brand new 9 bumper with se lip.
I dont know how to get those tabs back on there, because my epoxy job broke as soon as I tightened the screws down.
Old May 7, 2012 | 04:54 PM
tsidrift1's Avatar
Next time try to roughen up the surfaces you are using the epoxy on. It helps the epoxy "bite" into the plastic. Its worked for me for the last 4 months so far.
Old May 7, 2012 | 09:01 PM
evo2nv79's Avatar
How long did you let it cure before you bolted it back on?
Old May 7, 2012 | 09:03 PM
SavEVOIX's Avatar
I use poly urethane
Old May 7, 2012 | 11:19 PM
hokiruu's Avatar
Awesome thanks for the replies guys. At the time I didn't have any sandpaper, rubbing alcohol etc, or garage and was in a hurry so I guess I'll try it again now that I have all those. Except now my toolbox with the busted off tab in it got stolen
Old May 8, 2012 | 04:57 AM
NJ9MR's Avatar
FCOTM Winner
Hot glue!
Old May 8, 2012 | 07:19 AM
boostedmkiii's Avatar
Originally Posted by SavEVOIX
I use poly urethane
Good idea.... My first attempt would have been to use JB Weld.
Old May 8, 2012 | 10:45 AM
GgreyEVOIX's Avatar
Hey man I just installed a carbon fiber lip on my IX and have my OEM lip sitting in my garage. If it's any help I can give it to you if you want since it's just taking up space in my garage.....
Old Jun 23, 2012 | 05:16 PM
D@ve's Avatar
Can the brackets be bought separately? I can't find them online anywhere. I have the same issue, 03 Evo 8. Thanks!
MisUnderStood
Jun 28, 2017 10:20 AM
MisUnderStood
14
May 18, 2016 03:57 AM
Sheasta
Nov 15, 2015 12:29 PM
06MREvo
Northeast Region
17
Sep 23, 2013 05:32 AM
Darkrider3
May 4, 2011 09:24 AM
