Make Your Own Engine Dress Bolt Kit
Old Jun 1, 2012 | 10:17 AM
  #46
vortico's Avatar
Originally Posted by Q15H
Be SURE to use an anti-seize lube when installing stainless fasteners into aluminum to prevent electrolysis corrosion.
Any anti-sieze do? I'm pretty sure I have this stuff at home: http://www.permatex.com/products/aut...ubricant_a.htm
Or do you need a different type?
Old Jun 8, 2012 | 10:14 AM
  #47
Q15H's Avatar
Yes, that will work great for those bolts.
Next time you get some more, get the 2400 degree F rated stuff and use it generously on all the exhaust system bolts too.
Old Jun 9, 2012 | 03:28 PM
  #48
Ok Boys. Just received my SST bolts/lock nuts & washers. Cost approx $36.00
All in all, a modest, positive appearance change. Enjoyed the quick project
Here's what I ordered. Change your qtys as needed
Qty 6 / 6mm-1.0 x 12mm Metric Socket Head Cap (18-8 Stainless grade)
Qty 7 / 6mm-1.0 x 18mm Metric Socket Head Cap 18-8
Qty 5 / 6mm-1.0 x 25mm Metric Socket Head Cap 18-8
Qty 18 / 6mm-1.0 x 14mm Metric Socket Head Cap 18-8
Qty 2 / 8mm-1.25 x 20mm Metric Socket Head Cap 18-8
Qty 4 / 8mm-1.25 x 25mm Metric Socket Head Cap 18-8
Qty 7 / 8mm-1.25 x 16mm Metric Socket Head Cap 18-8
Qty 4 / 8mm-1.25 metric hex nuts 18-8
Qty 36 / 1/4 x 5/8 flat washers stainless steel
Qty 13 / M8 flat washer stainless
Qty 36 / M6 lock washer stainless
Qty 13 / M8 lock washer stainless
Old Jun 9, 2012 | 03:36 PM
  #49
foxbear2277's Avatar
^^^ Much nicer than stock, love allen bolts too but the bolts around the fender and on the hood just look too tall in my personal opinion. Still way better than stock, other than that, it looks mint!! You simply cant beat the price
Old Sep 3, 2012 | 03:40 PM
  #50
johnnnyjeans's Avatar
delete
Old Sep 4, 2012 | 09:17 AM
  #51
hppwdn's Avatar
I've been using Bolt Depot for awhile as well. On my last project I did just about every visible bolt and nut. It's a great finishing touch.
Old Sep 13, 2012 | 07:30 PM
  #52
https://www.evolutionm.net/forums/ev...installed.html
Old Sep 16, 2012 | 06:48 AM
  #53
Solenoid's Avatar
Veteran: Marine Corps
Great job on all the bolt projects posted
I think the steel allen's used in this heat shield look good Joe. Great job!
Mike
Old Sep 21, 2012 | 12:34 PM
  #54
ragyan03's Avatar
This is confusing...I think this is what you should do..you should post up the bolts together with the location of where they go..like the 6x10x12 go with the headlights, reservoirs etc..and the engine bay/valve cover bolts..cuz i'm confused in where all the bolts go lol..but they look great
Old Sep 21, 2012 | 12:47 PM
  #55
or you can unscrew the bolts and see if they fit. there's only 2 thread size. LOL.
Old Sep 21, 2012 | 12:49 PM
  #56
ragyan03's Avatar
Haha ok thats good..there was just so many different ones that I didn't want to mix then
Old Nov 10, 2012 | 10:44 PM
  #57
steelfire19's Avatar
Did this to my bay tonight, painted a few of them to see which ones i like better.
Old Nov 11, 2012 | 12:46 AM
  #58
llDemonll's Avatar
where'd you get those bolts from?
Old Nov 11, 2012 | 06:38 AM
  #59
smoOVE's Avatar
can anyone tell me what size bolts are for the heat sheild and manifold? when i bought my car it didnt come with a heat sheild or bolts and i bought a heatsheild i just dont know what size bolts it uses? Thanks.
Old Nov 11, 2012 | 06:45 AM
  #60
vmrevo9's Avatar
Veteran: Air Force
subscribed!
