And the counts:
Small Flat-Head Tapered Bolts (6mm x 1mm):
Large Flat-Head Tapered Bolts (8mm x 1.25mm):
Small Socket-Cap Bolts (6mm x 1mm):
Total:
I would order extras of stuff. It's dirt cheap and if you end up having to pay shipping again you will kick yourself (shipping is was $10 on my first $25 order and was $10 on my most recent $5 order). Order extras now and just have them on hand if you need them! There are many other bolts in the engine bay that you can replace, these are just the "main" ones that I did
Things I would order extras of (maybe 10 each? they cost next-to-nothing anyhow)
THIS KIT WILL NOT REPLACE:
| Qty. | Size | Location | ID |
| 6 | 25mm | Fenders (Both Sides) | #6689 |
| 4 | 25mm | Headlights | #6689 |
| 2 | 25mm | Fusebox | #6689 |
| 2 | 25mm | Radiator Tank | #6689 |
| 2 | 25mm | Front Bumper | #6689 |
| 16 | #14 | Finishing Washers | #2941 |
| 2 | 25mm | ACD Tank | #6700 |
| 2 | 25mm | Radiator | #6700 |
| 1 | 25mm | A/C Line | #6700 |
| 2 | 25mm | P/S Tank | #6700 |
| 1 | 25mm | P/S Line | #6700 |
| 2 | 25mm | Radiator Fan) | #6700 |
| 10 | 5/16" | Finishing Washers | #5579 |
| 6 | 25mm | Valve Cover | #6420 |
| 2 | 14mm | Top of Engine | #14996 |
| 4 | 12mm | Spark Plug Cover | #6417 |
| 3 | 20mm | Timing Cover | #6419 |
| 2 | 12mm | Radiator Hose | #6417 |
| 1 | 12mm | My Boost Controller | #6417 |
| 18 | 6mm | Flat Washers | #4516 |
Total:
| Qty. | ID |
| 16x | #6689 |
| 16x | #2941 |
| 4x | #6700 |
| 4x | #5579 |
| 10x | #6420 |
| 2x | #14996 |
| 6x | #6417 |
| 3x | #6419 |
| 18x | #4516 |
| Qty. | ID |
| 10x | #6689 |
| 10x | #2941 |
| 6x | #6700 |
| 6x | #5579 |
| 6x | #6420 |
| 6x | #14996 |
| 12x | #4516 |
- The four bolts on the top of the front bumper (I'm missing some hardware so there's nothing to screw them into. You could also buy some #4776 or #4795 nuts to screw the 4 bolts into that you'd put there
- Grounding bolt just below the front of the fusebox. I'm not an electrician so i didn't replace this but I'm assuming there's no issue using a stainless steel bolt for this?
- The two bolts holding the larger fan on the engine-bay side of the radiator. These bolts are threaded like wood screws and I'm guessing they screw directly into the plastic as opposed to being truly threaded
- Any of the bolts on the right side of the engine by the valve cover (cam angle sensor and whatever the hell else is over there)
It's not letting me edit on my phone (ill edit in the morning), the above should be titled in this order:
Small tapered bolts
Large tapered bolts
"Normal" bolts
Small tapered bolts
Large tapered bolts
"Normal" bolts
Quote:
Small tapered bolts
Large tapered bolts
"Normal" bolts
Really appreciate the effort into documenting this. I'm headed to fastenal today to get some SS hardware...Originally Posted by llDemonll
It's not letting me edit on my phone (ill edit in the morning), the above should be titled in this order:Small tapered bolts
Large tapered bolts
"Normal" bolts
Once i get everything how I like it I plan on taking pictures of all the bolts it replaces (rather than just an over view picture like I did) and making a new thread similar to the COP thread so that the info is readily available for those interested
glad you like it
the only important this is 6mm x 1mm threads for the small bolts and 8mm x 1.25mm for the large bolts. the head of the bolt can be whatever you want it to be!
glad you like it
Bolt depot is the only way to go when wanting to get your own engine dress up.
I was the only one that I knew of that had these, no it seems like everybody has them.
Shouldnt have given away my secret hahaha
P.S. You can use the 6mm flat head tapered bolts with the finishing washers for the valve cover too. They fit perfect.
Quote:
If you can wait a few days, just order everything from boltdepot, trust me.Originally Posted by RevMatcher
Quote:
Yea, I had those on there for the first pics I took but I liked the look of the raised bolt more personally. that's why I recommend anyone ordering bolts also order extras in case they want to switch things aroundOriginally Posted by tsidrift1
Quote:
this. it's going to be at least half the price, probably closer to 1/3 the price by ordering from boltdepotOriginally Posted by tsidrift1
Quote:
I appreciate you giving it away Originally Posted by tsidrift1
Quote:
You were right Originally Posted by tsidrift1
... Fastenal was really expensive! I'm ordering everything from boltdepot now!Evolved Member
Yea, I went with a buddy one day as he refused to believe bolt depot was cheaper, wow, what a difference hahaOriginally Posted by RevMatcher
You were right
Thanks tsdrift1. I'll be doing this after my car is done getting the little kinks fixed!
Nice thread
I think I'll move to USA just because of this thread and the fact that bolt depot doesn't ship to Canada. I'm jealous that you pay 35$ shipped for all this. It'll cost me 70$++
How much did you shell out for the password jdm stuff?
I have buddies thats ordered stuff from password for their hondas, almost everything Ive seen come from them is complete garbage. Terrible fitment, un even weaves, buddies amber corners didnt fit worth a ****.
