Evo VIII Build in The Mitten State
Thanks guys! I'm stoked to get the wheels and coilovers on the car as well.
Alright, quick update this morning. My gauge setup and shifter trim/ash tray arrived last night. I'm not finished with wiring the gauges or installing the sensors, but had to toss it in for a quick mockup pic or two. Still working out the details, but here's a teaser for now:
Things should really be picking up in the next couple of weeks as my stuff starts to arrive. Hopefully just in time for spring, if it ever gets here.
Thanks for the comments!
No plans to run one at this point. The car had one when I bought it, but I didn't really like it. I'm planning to stay stock turbo with very mild/basic mods and a conservative tune at this point, so I don't think I really need to clutter up the interior with one.
I'm not really sure what you mean about the HVAC system? I want to remain as much of a factory look as possible, so I'm not really sure there is anything I would do differently in that respect.
As for comparing the Evo to the 240, the cars are night and day in a lot of respects. I haven't really ragged on the Evo much at all since I bought it since I still have not had it tuned, but they feel fairly comparable power wise. My best in the 240 was a 12.9 at 114, and I think the Evo would probably be capable of a very similar time with a little bit slower trap speed.
My new OEM SE lip arrived on Friday from MitsubishiParts.net, so I did a quick test fit. Not really a new or ground-breaking look by any means, but I do think it should look pretty good!
Excited to not be driving around looking like this anymore...
I dropped off the bumper and lip at the body shop this morning, so it should be ready to go in a few days. I was going to wait until my JDM rear was here and ready to go as well, but I am too impatient.
So that will probably arrive in the states and hit the car sometime in late April or early May.
I ordered my coilovers from KW and my OEM top hats for the rear last week, so I hope to see those items arrive in the near future. I'm still debating tire size, but those will be ordered and mounted up on the CR Kais as soon as I decide. I'll probably wait until the temps are holding steady above 45 degrees and the coilovers are on before I install them anyway.
So that will probably arrive in the states and hit the car sometime in late April or early May.I ordered my coilovers from KW and my OEM top hats for the rear last week, so I hope to see those items arrive in the near future. I'm still debating tire size, but those will be ordered and mounted up on the CR Kais as soon as I decide. I'll probably wait until the temps are holding steady above 45 degrees and the coilovers are on before I install them anyway.
I would say he did a fmic, a full exhaust and a intake pipe with some tuning he would run much faster then 12.9. I know the guy who use to own my car before me ran 12.2 with just an exhaust and a tune but not real fair to compare being it is an rs
Ok so let me get this straight, your running oil temp, oil pressure and a boost guage but yet your not gonna run a wide band at all? You say that its mildly modded which it is, but how do you know what kinda conservative tune your gonna get without knowing what afr your running? I mean sure tune it on a dyno and forget about it but what happens down the line when you get a pin hole or something in the system and your making a pull and your car goes boom in a big way cause you don't know when to let go of the throttle being you notice your cars going lean as hell? With as much work as you have done and the car really does look nice why for the love of god would you not run one?
People tend to sometimes take a wideband gauge as gospel, and for a high horsepower setup I do agree that it is helpful. But honestly, if you're going to spend that much time watching your light show on the dash while driving, I don't want to be on the road with you.
This car is going to spend 98% of its life at 75 MPH driving to work and back on the highway.No offense, but I think you're overreacting a bit. Obviously when the car is tuned a wideband gauge will be present- it's not going to be tuned blindly and then beaten to hell and back.
I'll be the first to admit that the Defi gauges I have added to the car are more of a novelty item than anything else, but that's the beauty of it- it's my car.
From what I have seen so far, this seems to be one of those communities that feels EVERYONE needs to run a wideband gauge at all times, regardless of modifications. While the Toyota community I was a part of years ago was the same way, the 240/SR20 community was the total opposite. I ran a decently modified SR with a larger turbo, cams, standalone, etc without a wideband after dyno tuning the car once and forgetting about it for about 30k miles without issue. If you have a good tuner, it's truly not a big deal.
I can definitely respect your opinion. While it may be riskier, I honestly don't feel that running a very mild stock turbo setup without a wideband gauge is any more dangerous than running a 4-500 WHP setup on stock internals with a wideband gauge present. Just a little food for thought...
An engine can fail for a number of reasons at any given time. I guess it's just a part of the game we play. Like you said, it could definitely save you at some point under the right circumstances. I just don't think I'll run one if I'm honest.
I'm still pretty new here and learning a lot about what the factory ECU is capable of, but is there a way to set it for some kind of alarm under lean conditions? I'm thinking back to my Supra where I had the AEM set up to illuminate the MIL light in the gauge cluster if I was running above a certain AFR while over a certain boost/load threshold. Even though I had the AEM serial gauge which could display AFR's, I didn't always have it on the AFR display setting and I certainly wasn't always watching it. The MIL light in the cluster was noticeable even out of the corner of my eye while watching the road so i could react immediately if there was a problem. Now that I think about it, the serial gauge itself could also be programmed to display a visual or audible alarm based on a condition; say, running lean.
Any way to accomplish an visual or audio alert for such a condition using the factory ECU? If so, then I agree that an AFR gauge is not necessary aside from tuning.
