Brake Dust remover
Old Feb 7, 2013 | 09:06 PM
racing_girl's Avatar
Brake Dust remover
Hawk track pads kept me alive when needed but left my wheels scared for life. Looks like gravel stock to my wheels, have used pretty much everything I can find on autozone that says brake dust remover with no luck, specially in the corners. Recently a friend suggested paint thinner, I have the OEM evo IX Enkei wheels. I can see other people having my same issue...maybe someone came across the solution? Ideas are welcome.
Old Feb 7, 2013 | 09:30 PM
GTijoejoe's Avatar
Normally track pads like that will ruin the finish on the wheel even if you do get it off, detailing section is where you want to ask this question.
Old Feb 7, 2013 | 09:53 PM
KevinECSP's Avatar
I found using a claybar helps remove built up brake dust well, and far less harmful to your wheels than brake dust removers.
Old Feb 8, 2013 | 05:52 PM
Thanks for the help will give clay bar a shot...mods if you could move my post into the correct place. I didn't even notice there was a detailing section
Old Feb 8, 2013 | 06:05 PM
xXANCHORMONXx's Avatar
sonax works well
Old Feb 8, 2013 | 08:27 PM
EVO196's Avatar
Simple green is very good.......
Old Feb 9, 2013 | 01:16 PM
JDMevoBOOST's Avatar
Another thing you can do is to make sure your track wheels have wax on them prior to the track day. That way it should be easier to get it off afterwards. Doesn't really help with the stuff that's stuck on there now though.
Old Feb 9, 2013 | 01:24 PM
RussellDaniel's Avatar
Soap and water. Then finish off the wheels with Windex. I have black wheels and trust me works better than any cleaners
Old Feb 9, 2013 | 01:56 PM
evobros's Avatar
Clean them really good and spray them with a clear coat of paint and the dust should come off fairly easy. I've seen Cali ppl do that
Old Feb 10, 2013 | 07:11 PM
boostedwrx's Avatar
This, kinda. Clean them completely & put some Opti-Coat on them. Maybe do a test spot first depending on your wheels finish. I did it to my flat black RE-30's when I first got them and can still rinse the brake dust off. If I let the brake dust sit for too long they do require a normal cleaning but the OC makes it easier. I hate cleaning RE-30s...
wowzers
Mar 15, 2014 04:31 AM
94AWDcoupe
Jan 29, 2014 09:35 PM
buckmarley
Jul 2, 2013 01:35 PM
WangMan
Lancer How Tos / Installations
May 27, 2013 12:48 PM
O0oDC
Jan 30, 2013 09:42 AM
