How To Request: Wheel Stud Replacement
I've done some searching and found a lot of useful info, but haven't had any luck finding a good "How To" regarding replacing my wheel studs.
There seems to be a couple issues that I keep seeing in other posts including the dust shield getting in the way (plus, haven't seen anybody cover the rear wheels).
Is there anyone who has replaced their wheel studs before that can answer a couple of my questions? I may put together a write up when I actually get around to this, but until then I need to know how to get around the dust shield in front and if I need to remove the entire drum brake assembly to get to the rear studs...
Any help is appreciated
I wish i could say for certain... The evo hubs are bolt in... 4 bolts on the back side of the knuckle... I pulled mine... Tapped the lugs out on the bench and reinstalled...
Not sure if you guys have bolt in or pressed in hubs though
Autozone says pressed so ignore my input
Gtizks
11
Jan 5, 2017 08:11 PM
Hi Im Vinh
Aug 26, 2012 01:32 PM
timdog4life
Sep 18, 2004 05:01 PM
