my 1993 evo 1 repaint and tweak
Old Jul 10, 2014 | 02:50 PM
  #151
4G63Rules's Avatar
Video to come once it is all finished.
Old Jul 13, 2014 | 07:36 PM
  #152
ImEv0's Avatar
just went through all 11 pages. i hope to do something like this one day. keep up the great work and yes, videos please!
Old Jul 13, 2014 | 07:47 PM
  #153
oscarquinones's Avatar
the car is nice but how do you driving this car in the opposite side.
Old Jul 14, 2014 | 06:45 AM
  #154
94AWDcoupe's Avatar
I just pretend its a postal vehicle... but seriously it does take time getting used to. shifting with left hand kinda makes it like learning to drive all over again. the blinker is reversed so after driving a RHD car you are forever messed up trying to hit the blinkers in any car. 50% of the time you will be hitting the wipers. applies to driving both RHD and LHD cars. the other thing thats hard to deal with is the attention the cars get from people with less that a full deck upstairs. "hey man, your steering wheel is on the wrong side! " gets old real quick.
Currently at a crossroad as far as the tune is concerned. I spent likely about 40 hours on the tune three years ago. the drivability was perfect and I didnt touch the tune for three years. now there have been some simple changes. the cams, and the alternator. and the a/f is completely off. shockingly so. I am thinking I dont want to spend a bunch of time retuning with DSM link. I think I am ready to jump to AEM infinity.
Old Jul 16, 2014 | 10:29 AM
  #155
06MREvo's Avatar
Car & engine bay are clean, great job! And 2640lbs with you in it is awesome! Love this car!
Old Jul 17, 2014 | 04:03 AM
  #156
94AWDcoupe's Avatar
looking at logs I am rich and only hitting 16lbs boost. perfect for breaking in the motor. when the eth level gets low the mixture leans out some. so on monday with low eth level I came around a corner at low rpm in 2nd gear and hit it. felt some real yank for the first time. really took me by surprise how much power it has for such low boost.
so today this became this
Old Jul 17, 2014 | 11:41 AM
  #157
4G63Rules's Avatar
I will be over there tomorrow. We need some action shots in its current state.
Old Jul 18, 2014 | 04:29 PM
  #158
94AWDcoupe's Avatar
Old Jul 19, 2014 | 08:50 AM
  #159
wreckleford's Avatar
Are you using a 2G DSM ECU or the Evo ECU? I know someone looking for a 2G Eprom ECU.
Old Jul 20, 2014 | 05:57 AM
  #160
94AWDcoupe's Avatar
2G V3. nor sure the link will be up for sale. might be a few weeks before the AEM is ready .going to make it plug-n-play using a patch harness . I want to be able to keep ECU options open.
Old Jul 23, 2014 | 03:21 PM
  #161
Ironchief's Avatar
This car is a classic!
Old Aug 4, 2014 | 10:38 PM
  #162
94AWDcoupe's Avatar
so I had another setback. hydro bearing starting leaking. ticked I had to pull trans I let car sit for a week. I had 1/4 thick aluminum brackets holding bearing together. but three bolts were not enough and it started to flex and leak. . so this time I used 10 screws to hold it together. I also traced the rattle to the floating calipers. so I added some small allen screws to the pins to eliminate slack. they are now quiet. I also added isolators to my custom roll stop bar. that was actually the most annoying mod that was done. far too much noise and vibration coming through. with the isolators its a huge improvement. car is close to dead quiet now. finally time to focus on dialing in the power band.
Old Aug 4, 2014 | 11:25 PM
  #163
alpinaturbo's Avatar
Very cool car, looking forward to see the tuning progress.
Old Aug 5, 2014 | 07:12 AM
  #164
InoNothingMR's Avatar
Old Oct 5, 2014 | 12:55 PM
  #165
94AWDcoupe's Avatar
I have been struggling for last two moths with an inflammation in my right eye. So I havent had much time to put into the car. started to play with the virtual dyno software. we lost our local dynojet so its not convenient to get a dyno pull to see where the car is at. The software does not have the early evo for data selection. So I have to create settings on my own. last two times on a dyno jet the car made 426/405 (44.5lbs.) and 459/421 (47.5lbs) these two pulls were right around 51lbs peak so i think I am pretty close. close enough to do some tweaking with. so this will kinda of serve as my new baseline for now.
