installing system... help with routing wire
Old Mar 13, 2004 | 03:16 PM
cky3396's Avatar
hey hey
so ive got all my wiring, amp, speakers, etc for an install
im using 1/0 power from the battery back to a dist block then into a 300/4 & 500/1
the thing is, im stuck on where to route the main 1/0 power wire. theres absolutely no room in the little tube that has all the factory wiring for the door
im just stuck on this.
also, im having a tough time with my knukonceptz positive battery terminal and the rest of the factory power wire that needs to be connected.. i just cant fit it all on the new 1/0 terminal thing
if anyone has suggestions, id appreciate the help
Old Mar 13, 2004 | 03:21 PM
Sailorgoon's Avatar
There should be a grommet under the glove box on the passenger side. I ran the cable from the battery, across the strut bar, down into the gommet. From there, you can pull up the sill plates and run the wire under the carpet. You need to remove the two passenger side plates and the passenger side B-pillar molding to get a clean run.
It's a perfect place to run the signal and antenna wires too. The 1/0 cable is a little bigger than what I used, but it shouldn't pose a problem.
Old Mar 13, 2004 | 03:28 PM
cky3396's Avatar
cool ill give that a look, thanks
how did you deal with the battery terminal connections/
Old Mar 13, 2004 | 03:46 PM
StreetPowerEvo's Avatar
I agree with running through the firewall but be leary of running your imput/signal lines down the same channel/side of the car as your power line. A 1/0 can generate a lot of interference and cause 'humming' and other distortions in you audio output (learned the hard way)
My 2c
Old Mar 13, 2004 | 04:14 PM
cky3396's Avatar
yea my speaker/RCAs will be on the opposite side
Old Mar 14, 2004 | 07:54 AM
Grod101's Avatar
also run your control wire for the amp on the opposite side of power....
Old Mar 14, 2004 | 08:27 AM
Oh yea forgot about the remote
Old Mar 14, 2004 | 12:14 PM
cky3396's Avatar
any of you guys have photos of that place to route the power thru the firewall on the passenger side?
Old Mar 14, 2004 | 04:41 PM
bobs blue evo's Avatar
Run a search on firewall pass through, theres a big post about it. I put a 4 gauge wire back to two amps through there. You will need something to poke it out with, it's not really that accessable. One tip if you are replacing speakers, check the forums for models which directly fit and clear the windows. I spent a lot of time making spacers to mount standard 6 1/2" speakers in front doors and rear deck.
Old Mar 15, 2004 | 01:11 AM
cky3396's Avatar
thanks dude
Old Mar 16, 2004 | 01:10 PM
justchil's Avatar
Click for supersized pic... You may have to do some work to the gromet to make 0/1 gauge fit.
Old Mar 16, 2004 | 08:52 PM
cky3396's Avatar
thanks, got it.. i've routed the power to the rear already
Old Mar 17, 2004 | 10:26 AM
Coolguy949's Avatar
what kind of 0/1 did you get? That must be a nightmare to maneuver around the car.
Old Mar 18, 2004 | 10:09 AM
cky3396's Avatar
knukonceptz..... it was pretty easy to route, actually. that hole in the firewall makes things pretty easy
