1st time shooting flames
Old Apr 7, 2015 | 07:41 PM
blackoutVIII's Avatar
So Saturday I installed what I thought were NGK BPR8ES plugs, but after I realized the boxes were missing the "P" and the box said BR8ES. did some research and found the BRS are 1.5 cooler than stock plugs and .5 cooler than the BPRs. So no harm no fould, I think..... Today, I decided to rev it up a little since I heard the cams rumbling more than usual. It is a little rumble, since cams are not all out. Started up the gopro to get the sound and when I revved it up, hit the launch control rpm range and kaboom FLAME shot out!!! What do you guys think?
Old Apr 8, 2015 | 04:14 AM
meckert's Avatar
You need to do better home work..the numbers reflect the heat range of NGK plugs, for reference see http://www.ngksparkplugs.com/docs/te...bols_plugs.pdf.
do youself a favor and put the correct plugs in your car and just stick to driving it.
Old Apr 8, 2015 | 04:36 AM
stiffdogg06's Avatar
I know I'm new to posting but isn't the stock heat range a 7? You have 8's which are a full step colder, no?
Do you have a need to go a step colder?
Old Apr 8, 2015 | 04:41 AM
Yes, I know they reflect NGK. That is what I have used since installing all the bolt ons in my signature block.
QUOTE=meckert;11425766]You need to do better home work..the numbers reflect the heat range of NGK plugs, for reference see http://www.ngksparkplugs.com/docs/te...bols_plugs.pdf.
do youself a favor and put the correct plus in your car and just stick to driving it.[/QUOTE]
Old Apr 8, 2015 | 04:46 AM
Yes, I was a full step colder. The reason is to run more boost. I am now a step and a half colder by mistake. But, the car seems to be a little more responsive now than before. Which I like and the flame shooting out was me just messing around and wanted to just catch the rumble noise from the cams and compare it to the sound clip from previous times. Flame just happened, wasn't the original intent.
Old Apr 8, 2015 | 11:37 AM
llDemonll's Avatar
You don't need anything but the stock heat range with boltons. You're not getting any benefit from running a colder plug than stock. anything you might notice is placebo
Old Apr 8, 2015 | 12:37 PM
Veebong's Avatar
What's up Bro it's Mike!
Old Apr 8, 2015 | 12:45 PM
sujinX's Avatar
do u have a cat or no? sig says catback.
how much boost are you running? typically dont need colder plugs for moderate bolt ons.
Old Apr 8, 2015 | 05:57 PM
Test pipe and running 25 lbs of boost
Old Apr 10, 2015 | 09:29 PM
codgi's Avatar
This. End thread.
qu evox
133
Dec 2, 2020 08:39 AM
JdMeVo4
18
Feb 8, 2009 11:15 PM
Derek888
15
Sep 12, 2008 02:19 PM
ppayer38
Mar 11, 2008 10:05 PM
vegasboy301
May 18, 2006 04:51 PM
