Factory Key less
Factory Key less
Ok, I was installing my boost gauge, and it works and all. The dim lights work too.
Ok, heres the situation, my keyless entry dosen;t work. Doors and winders work, but its the key less entry that isn't working. The other thing is that when I open my door, I hear the chime. You know the chime that reminds you that the key is in the ignition. But the keys are in the pocket. Im not sure whats causing this and somone here might know.
TIA
Joseph
TIA
Joseph
boost gauge are both wired to the ciagrett lighter.
3 wires. Ground, Power and dimmer. The only other wire thats hooked up is the ignition wire. Same wire you hook up to for the turbo timer.
well thats why .... you shoulda hit the cigarette lighter LED light... i think you messed with the flow of the grounding...
actually i recommend getting power from the ecu harness
the boost gauge was installed 2 weeks ago, and this problem started yesterday. The dimm light on the cigaret lighter was good enough to work 2 weeks ago, and so was the ground.
november
17
Jan 11, 2021 06:03 AM
lonepatrone
Jul 25, 2007 07:46 AM
