Help with keyless entry.
Old May 25, 2011 | 11:19 AM
suicidevo's Avatar
I was trying to instal a greddy turbo timer(without the harness) i was following a diagram of which wires needed to be spliced. long story short the turbo timer didnt work and my key-less entry stopped working. The chime goes off with no key in the ignition and when the door is open and shuts off when the key is in. i know there is treads on this but they lead to no solution other then (going to the dealership) which costs too much. I need someone tell me exactly what to do to fix this. there is no TT on the car anymore.
Old May 25, 2011 | 11:28 AM
MrDgaf's Avatar
Just buy the harness. Simple
Old May 25, 2011 | 11:29 AM
suicidevo's Avatar
i don't want the turbo timer. i just want to fix the key-less entry
Old May 25, 2011 | 03:28 PM
stabiemcstabin's Avatar
Did u undo what you did as far as the wiring u sliced ?
Old May 26, 2011 | 11:49 AM
suicidevo's Avatar
yes no wires were cut. just tapped into
Old May 26, 2011 | 12:00 PM
KWezzy's Avatar
Man just untap them and hook it up like normal then get a harness.
Old May 26, 2011 | 12:04 PM
Bobster22388's Avatar
If you hooked the wires up wrong you could have shorted out something in the ignition system. Did you check all your fuses? Only other thing I can think of is the ETAC module that controls all the buzzers and misc. interior things.
Old May 27, 2011 | 02:07 AM
Yea what he sad the E-tacs ecu control the door chime and keyless, I hope u didn't smoke anything
Old May 27, 2011 | 06:57 AM
suicidevo's Avatar
the fuses are fine. what happens if i shorted the etac. and where is that. i remember reading something about putting paper and a rubber band on something to fix it. but there wasnt much inof on it.
Old May 28, 2011 | 09:25 AM
suicidevo's Avatar
i know someone had this problem any help?
november
17
Jan 11, 2021 06:03 AM
Vaalie30
Jul 9, 2010 03:07 PM
Juan Martinez
18
Aug 29, 2007 01:24 PM
GOKOU
Jul 17, 2005 08:40 PM
HoustonEVO
Dec 3, 2003 12:34 PM
