Wheels for Evo StopTech 332 mm Kit
Subscribe
Dec 18, 2004 | 12:40 PM
What is everyone using for wheels with the front StopTech big brake kit that uses the 332x32mm floating rotor? Any 17" wheels that you know of that fit?
Reply 0
Dec 18, 2004 | 03:27 PM
StopTech brakes
bump
Reply 0
Dec 18, 2004 | 04:42 PM
StopTech brakes
bump
Reply 0
Dec 18, 2004 | 05:03 PM
vivid racing threw some wheels on their evo 8 that had stoptechs, not sure if their your size or not, but check with them and see what size wheels they put on their car.
Reply 0
Dec 18, 2004 | 05:45 PM
Quote: What is everyone using for wheels with the front StopTech big brake kit that uses the 332x32mm floating rotor? Any 17" wheels that you know of that fit?
You do know that stoptech also has a 355mm kit, right? Anyway this is what I'm using:
18x8.5 30mm and 18x9" 40mm TE37's. BTW, the stoptech caliper sits a few mm further inside than the stock Brembo, so pretty much any wheel that clears the Brembos should be OK.
Reply 0
Dec 19, 2004 | 07:34 AM
StopTech and wheels
I now own the Vivid Racing Evo with the 322 mm StopTech kit, front and back. They are far better than stock Brembos that I have on the other Evo that I own. The Vivid car has 18 inch Advans and the other Evo 17". To my surprise yesterday I found that the 17" do not fit on the StopTech hubs because of the diameter of the hub hole in the wheel is smaller than the circumfertial flange on the wheel hub. Before buying a second set of wheels for the track for the Vivid car I was wondering what other StopTech users are using for their cars. I had hoped to end up with the same size wheels and track tires on each car without spending a fortune to do so.
Reply 0
Subscribe
